Is this noise power cycle, or shorting?
+ More Options
Posts
  • Spode
    • 41
    Hi Guys,
    Trying to fix another TV (now have a small pile of them that I'm struggling with).
    The unit was turning on, and after a short amount of time, the backlights would stay on but the signal to the unit would just stop and then slowly fade away off screen (logic board issue?).
    I found a swollen cap in the PSU which I replaced - on the 24V side of things. Made no difference.
    The PSU was making a bit of noise in the top right, which using a straw I found to be one of the large red ceramic capacitors. I decided that perhaps the power was failing to the logic board, so thought I'd investigate further.
    I decided to resolder the joints for the two transformers and the toroid coils on that side of the PCB.
    After that, the unit no longer turns on and instead I'm getting a fast clicking. I can't work out what I could have done wrong! I've checked everything I've soldered and all appears to be in order
    What does the sound in the MP3 file I've attached indicate? Is it arcing, or the safety mechanism of it trying to turn on/off?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Is this noise power cycle, or shorting?
    1) It would help if you listed the make and model number of the TV.
    2) A clicking suggests the SMPS is trying to start. It might be the small capacitor next to the SMPS.
    3) We could use a better focused picture of the picture as close to 2000x2000 resolution.
    --- begin sig file ---
    --- end sig file ---
    • Spode
      • 41
      1) Medion 20099-S 32"
      2) Did you listen to the MP3 I attached? I was wondering about the start-up cap, but it was working fine before I decided to re-solder the joints - so that didn't make sense?
      3) Attached something a little better. I really should dust off my SLR for these things...
      • retiredcaps
        • Apr 2010
        • 9271
        No. I'm not blaming you, but having been burned in the past with zip attachments, I avoid opening them.
        • retiredcaps
          • Apr 2010
          • 9271
          Still too blurry to read the legend next to all the connectors, but do you still standby voltage on any of the connector pins?
          • Spode
            • 41
            That's understandable - there wasn't a way for me to attach an MP3 though!
            Here it is on SoundCloud:
            http://soundcloud.com/spode-1/recording-20110210-184854
            Here are a few more pictures, from the SLR too to see if these help. Will check the standby voltages later. I found 1.2, 3.3, 5 and 24 when it was up and running.
            • retiredcaps
              • Apr 2010
              • 9271
              Comes up with an error message.
              SLR makes huge improvement.
              • Scenic
                o.O
                • Sep 2007
                • 2642
                lol for being that paranoid..
                the mp3
                http://bambooz.pytalhost.net/badcaps...210-184854.mp3
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Ok it looks like the unit was repaired before, because of the odd panasonic capacitor on the output, compared to the other crap-looking ones.
                  I think there is either too little load on the PS, or there is a short somewhere that you made. When you tested the PS did you put it in the TV?
                  -Ben
                  Muh-soggy-knee
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    blue -> G-Luxon
                    green -> seems to be CrapXon
                    black-gold -> Lelon
                    so pretty much the crappiest caps possible for a LCD TV PSU..
                    ticking sounds usually indicate that the PSU is trying to start up, but can't. either due to crapcaps or a short somewhere on the secondary side..
                    • mbates14
                      • May 2005
                      • 169
                      its funny though, it was working before you re-soldered. and not after, better check you didnt bridge a connection. ive done this by accident in the past.
                      • Spode
                        • 41
                        The black-gold cap was put in by me, to replace a swollen green one. Didn't make a difference though.
                        I think you're right mbates14 - it could well be a mistake I've made, but I've looked and looked and can't see anything
                        Before I started soldering, using a straw one of the red caps was making a noise. Now, the clicking is coming almost entirely from that same red cap. Could the cap have gone - or is it just an indication of something further down the line?
                        • Spode
                          • 41
                          I just plugged it all back in, and it made odd clicking noises, which sped up and eventually just became a hum - and it powered on as it was before I started working on it.
                          Worked for 5-10 minutes and then eventually the same issue occurred.
                          So now I'm pretty sure that I haven't made the issue worse - so the startup issue is probably related to a bad cap somewhere. So which area should I start replacing first? What is the most likely culprit?
                          • tony359
                            by tony359
                            11-28-2023, 05:18 AM
                          • MegaZAC
                            Onkyo TX-SR805 noise in one channel
                            by MegaZAC
                            Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                            Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                            There's some logic behind it. As soon as I select an input I get only left...
                            04-23-2025, 10:09 PM
                          • meraklinetx
                            Asus Z97-a power cycle, no boot no cpu voltage
                            by meraklinetx
                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                            05-10-2023, 06:08 AM
                          • ngml
                            Repair of an LG split AC system indoor unit PCB
                            by ngml
                            I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                            This indicates an error in the communication between the outdoor and the indoor unit.
                            The outdoor unit is fine, so the problem is the indoor PCB.
                            The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                            I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                            Does anybody have the schematics of this board,...
                            02-01-2025, 12:55 PM
                            A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                            by momaka
                            More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed โ€œFor part/not workingโ€, as usual. Showed up in a beat up EVGA box without any paddingโ€ฆ but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                            And a shot of the label:...
                            01-26-2022, 03:26 AM
