Heathkit SO-4552 oscilloscope help needed
+ More Options
Posts
  • Caleb
    Smokin IC's
    • Feb 2013
    • 645
    Re: Heathkit SO-4552 oscilloscope help needed
    The ring tester schematic is online as well, I built one for about 3$ mostly from junk box parts just had to order the 2 ic and the transistor (mouser has all the parts) I have found it very helpful in diagnosing inverter transformers.
    I think popeye was saying you can connect the collector pin to the emitter pin with a light bulb in series to supply a current limited source for your hv transformer.
    Liberating magic smoke one part at a time
    • wayne55
      • Jan 2011
      • 15
      I'm sorry I'm so slow, but do you mean to take a regular filament bulb and connect leads from the bulb to the emitter and collector holes where the transistor was mounted? Then turn the power on and if the bulb lights, does that mean the transformer is good?
        "I think popeye was saying you can connect the collector pin to the emitter pin with a light bulb in series to supply a current limited source for your hv transformer"
        The DC resistance of the transformer will be very low, so the lamp will light up, it does not mean the transformer is bad, that is not real valid test due to low DC resistance of the transformer winding.
        You can take the DC resistance of the transformer and see what you get.
        When you feed the transformer with AC, the impedance of the winding will be the one that determine how much AC current will flow throug the winding.
          A shorted turn would give the transformer very low effective resistance at AC frequencies, as well as at DC. I think the idea is that when the flyback is delivering power (and operating normally) it's got an effective AC voltage drop due to its inductance and the operating frequency, which draws considerably less than a shorted turn would.
            One or two shorted turn may not lower the DC resistance much if it has a couple 100 turns on it, putting lamp in place of the transistor will let the dc current flow through, the transfomer windig will act just like resistor, it has to be fed with AC. That's is why I ask for clarification of the lamp connection, may be the lamp in series with the transformer and with working transistor in place, not the lamp in place of the transistor.
            • wayne55
              • Jan 2011
              • 15
              #26
              I got the parts quicker than I thought and after replacing the bad transistor, the filter capacitor, both HV diodes and the 237 8 pin chip, I'm now getting all the correct voltages in the power section. I get the +12, -12, +5 and +145 just as it calls for. This is with all components in place. I also get the AC voltages of 6.3 and 31 that feed from the main transformer to the CRT.
              The bad news is that I still get nothing on the CRT display. The CRT rear end glows but no trace appears. At least now nothing seems to be getting too hot inside, but I did not think there would be more than 1 problem to deal with.
                You are going to need High voltage probe to find out if you do get 2KV or not from that high voltage section.
                • wayne55
                  • Jan 2011
                  • 15
                  #28
                  I don't have a real high voltage probe, but I have a volt-pen that lights when it is near high voltage. I use it to check an electric fence. I do not think I'm getting high voltage, because it does not light up when I place it near the -2Kv checkpoint. Maybe the high voltage transformer is the problem afterall.
                  • wayne55
                    • Jan 2011
                    • 15
                    #29
                    One more thing to add, I do get the +12 volts at L162 and the -12 volts at L161 as shown on the schematic.
                    • Caleb
                      Smokin IC's
                      • Feb 2013
                      • 645
                      Have you re-calibrated your vertical section? I had trouble getting my trace to appear on the crt (the position knobs weren't able to move it enough) until I re-calibrated the verticals, you also probably want to check the horizontal for correct voltages. I was able to measure mine with my dmm but my scope is only about 1100v (even though it says 1600v on the board) the manual says to expect about 1100v. Still hurts like a sob when you get too close.
                      • wayne55
                        • Jan 2011
                        • 15
                        #31
                        I contacted Pintek, the Taiwan maker of the scope. They said when the transformer went out, it normally took the transistor with it. Since the transistor was definitley bad, I assume that's what happened. There is a replacement transformer, but the cost of having it shipped and some kind of bank fee they charge make it cost prohibitive.
                        • mikey5791
                          Is it possible for transformer substitution?
                          by mikey5791
                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                          My questions are
                          1. How do i test to see if the transformer is in good working condition?
                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                          Hope you guys understand what i was asking. My intention is...
                          11-03-2022, 02:11 AM
                        • dennis_elx33
                          3PHASE STEP-DOWN Transformer in Check
                          by dennis_elx33
                          Hello All,
                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                          Problem statement: Power tripped Off
                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                          Action Done:
                          1) Replaced the faulty parts with good spare.
                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                          12-02-2024, 06:52 AM
                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 04:40 PM
                          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 12:00 PM
                          ASUS Transformer T304UA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T304UA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA boardview and T304UA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ASUS...
                          09-06-2024, 11:50 AM
