toshiba 37HL95 "no start"
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: toshiba 37HL95 "no start"
    the seine board is actually the main (LCD) controller board.
    what you're talking about is the "dumb" tuner board piggybacked on top of it..
    disconnecting the seine board is like unplugging the LCD controller board from a LCD monitor, leaving just the powersupply/inverter board running.. "a bit" pointless..
    • kingofcoins
      SaveOnGreen-Cap
      • Jan 2010
      • 162
      We're only talking about disconnecting one cable that's plugged in, not to remove anything...worth a shot as the ruse has worked for other Toshiba models.
      • scampo77
        • Dec 2010
        • 233
        i have tried unplugging most everything and in every combination that makes sense so far nothing has made any difference at all
        i appreciate everyones help but im not off to a very good start
        • riotpack
          • Jul 2008
          • 27
          Great so you have the manuals and the TV. Now you can use logic to troubleshoot the problem. Start with the mains coming in and main SMPS (You said the STB5v is ok) - Are the voltages ok before the main switching transistor, and what about the circuit that turns the main SMPS on and any protection that may have cut in. IF you want to make it safer you can solder a wire to the point you wish to check before applying any power and connect your meter and then apply power. Refer to page 18 of the manual, connector p813a, what voltages do you get here, monitor pin 3 and press the power button, any changes?
          Thats not a Fuhjyyu I used in your antec PSU its a HITACHI!! rofl lol lmao funni gui!
          • riotpack
            • Jul 2008
            • 27
            Also refer page 17 and check ALL the standby voltages are present AFTER any regulators etc. Find out what is missing.
            • riotpack
              • Jul 2008
              • 27
              #26
              I am hoping this is not corrupted firmware (location: seine board) - But before spending any money you can at least do voltage testing and see if something is upsetting the boot sequence.It may be a protection kicking in when something like the inverter kicks in, but keep it simple and start at the beginning, standby voltages and power on/protect circuit. Does it keep looping the flashing LEDs over and over? Is there any squealing sound, any sound?
              • jholiver3
                • May 2011
                #27
                Is one of the features you refer to the component video input? I have disconnected the seine board and now receive my digital cable feed (via HDMI and a cable box), but cannot receive any video from the DVD player connected to the component inputs. This is a Toshiba 50HPX95 by the way.
                Thanks,
                Joe
                • pinwizz69
                  • Jan 2012
                  #28
                  Originally posted by Scenic
                  https://www.badcaps.net/forum/attach...4&d=1296417297
                  looks like the resistor to the right of the top transformer has a chunk missing..
                  just something i noticed while looking at those pics..
                  there's also what looks to be a picofuse to the left of the transformer at the bottom. the green resistor-like looking thing..
                  Pico fuse,s are an overvolt/surge protection devise. I they fail you have a serious problem. It may have been hit threw the earth lug or a transformer blowing up in your neighborhood. I,,v seen it on Pinball/Arcade games in bars with hacked wiring. Best thing to protect your Electronics these days is cheaper than buying new electronics. It,s called a battery backup UPS. Get one with AVR included. It.ll have a min. rating of 850 VA to have AVR. Make sure ALL components and feeds ( AC , cable ect. ) goes threw the UPS before the TV,Stereo,PC units.
                  • maxcm96
                    • Mar 2012
                    • 5
                    • usa
                    #29
                    So what was the outcome of this project? Any updates?
                    • scampo77
                      • Dec 2010
                      • 233
                      #30
                      Its dead I threw it in the garbage
                      • selldoor
                        Slow Learner
                        • Dec 2010
                        • 7870
                        #31
                        "Its dead I threw it in the garbage"
                        That is a terrible waste - do you not have Freecycle in Montreal. I am sure
                        there are people who would have loved to get a spare ccfl and other bits.
                        Yes I see you do
                        http://groups.freecycle.org/freecyclemontreal/posts/all
                        • tvduude
                          • Jul 2012
                          • 67
                          i agree with selldoor. theres alot of tinkerers and enthusiast would like to learn from the
                          inside of that machine.
                          and i been told thats one of the best panels.
                            This TV is easy to fix too, it's just the 2.5V buck regulator on the HDMI/LVDS transmitter board.
                            • electronicsurplus
                              • Jun 2012
                              • 210
                              We have also found a problem that not only occurs on the Toshiba but, also on many Other LCD Televisions
                              Also a burnt out Transformer on the Inverter. many times also fails
                              We have found an easy (TEST FIX) for this, rather than trashing the TV or, buying a new Inverter
                              We have just completed this fix on a Toshiba 37HL95 and, worked perfectly
                              IF the Television screen flashes only for a second. take notice of which bulb is not firing. you can easily tell by the unlit area in the front of the screen
                              If you jump the white wire which connects to the corresponding bulb and, jump from a working bulb, using thick gauge wire (Because, there is high voltage stranded wire is preferred) This will force the bulb on
                              Hope this helps someone to help keep another TV from the Landfill
                              Anthony
                              Electronic Surplus
                              This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
                              Help keep these from the landfills
                              • jinjerayle
                                • Jan 2015
                                I have the exact same problem as Scampo77 with my 37HL95 TV, which I bought off Kijiji from some guy for $60. I thought it was a good deal until this happened. He told me the TV as 100% in working condition and no defects. Anyways, I've been looking all night for a fix and stumbled into this forum, thank goodness.
                                Anthony, you mentioned you found a fix to this problem:
                                "If you jump the white wire which connects to the corresponding bulb and, jump from a working bulb, using thick gauge wire (Because, there is high voltage stranded wire is preferred) This will force the bulb on"
                                Could you kindly elaborate as I am not a very 'techy' person, and I really do not want to throw this TV away. When it worked for the first couple of days, the picture was excellent. I just want to fix this as I do not have the budget to purchase the more expensive TVs out there today.
                                Also, I should perhaps mention that this started happening after I tried using the TV as an external monitor, connecting my Toshiba NB510 using a VGA cable.
                                Please help :-(
                                  09-06-2024, 05:27 AM
                                  09-06-2024, 05:59 AM
                                  Toshiba Portege Z30-C Notebook Specification for Upgrade or Repair
                                  This specification for the Toshiba Portege Z30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Z30-C boardview and Z30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                                  09-06-2024, 05:33 AM
