Ok so I have a sanyo dp50747 plasma that stopped working.. I got online and found that it was probably blown capacitors on the power board.. I pulled the back off and found nine bad capacitors.. I replaced these capacitors and bam the damn thing came on.. After a few days I encountered a new problem where after an hour or so the tv shuts off, If i unplug it and plug it back in it turns back on just fine and then its usually good for a while.. I thought it might be the small board where the plug goes in so I replace it as well but that didnt solve the problem can anyone tell me where to go from here???
Sanyo DP50747 Plasma
Tags: None -
Re: Sanyo DP50747 Plasma
Welcome, griffey8934!
Do you have a picture of the board with the bad capacitors?
And what were the brands and series of electrolytic capacitors on that board?My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics. -
I dont have a picture of the board but it is the lg model board for this tv.. The capacitors were a little higher rated and was sold in a replacement kit they all stil look fine..Comment
Have a quick question, our TV is on the brink also and was wondering what capacitors did you use, we pulled out the main board and we have 9 bad capacitors....was wondering which ones you purchased and where did you purchase them....ThanksComment
Posting the same problem in multiple threads is an excellent way to get ignored.
I suggest you start by reading the FAQs. They give plenty of information on identifying bad caps, and locating replacements.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by stecosHi everyone!
I happened several times, in the search for help from the web, to consult this very interesting forum.
So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
Having said that I come to the gist of my post on the forum as the title suggests.
For my passion for technology I'm now collecting several... - Loading...
