Sony KDL-46Z4100 Vertical Colored Lines
  • bigpapabooga
    • Apr 2013
    • 5
    Re: Sony KDL-46Z4100 Vertical Colored Lines
    i am new so dont kill me lol...does any one have a repair schematic for the aps-236\ 1-876-466-12 power supply for the kdl-40z4100?
    • paultexas
      • Oct 2013
      • usa
      Do anyone know what the flashing green light on the BU board (just to the right of the heat sink) mean, when the TV is power on?
      • visionbluedemon
        Help. Sony kd-65x85dj vertical lines
        by visionbluedemon
        First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
        Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
        tried blocking LC lines too, but same results
        is it lcd panel issue or tcon board issue?...
        07-25-2025, 04:56 AM
      • gpo23
        Sony KDL-40V3000 - Vertical lines
        by gpo23
        i order a t-con because i had bad colors on my SONY KDL-40V3000 :
        With the new t-con the color are good but there are vertical lines on all the screen :
        I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
        Is there a way to fix the vertical lines on the new t-con ?
        Thank you for your help
        gpo23...
        10-04-2023, 09:11 AM
      • Stanley1843
        Screen Display Vertical Multicolor Lines
        by Stanley1843
        Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
        06-29-2024, 11:54 AM
      • noisykid
        Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
        by noisykid
        5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
        12-30-2024, 07:15 PM
      • iampivot
        Three vertical lines without t-con board connected: Sony 55X8000F
        by iampivot
        I have a Sony 55x8000f that has three vertical lines (three different colors), with the lines still showing when the cable from t-con board to the panel is disconnected. Am wondering what might be causing this? Unfixable panel problem?
        04-18-2022, 06:41 PM
