Insignia NS-32lcd red ghosting??
  • reeves03
    • Jan 2011
    We have a Insignia ns-32lcd 1st model that displays kind of a red ghosting that changes with the image. Tried different input connectors and went through systems settings and nothing seems to affect it. Contacted Insignia support not very much help suggested it sounds like a color convergence issue and take it to Best Buy and let them look at it. Anyone here have any suggestions??
    Thanks,
    Jason
  • PlainBill
    • Feb 2009
    • 7034
    Re: Insignia NS-32lcd red ghosting??
    Thanks,
    Jason
    First of all, Insignia said 'convergence issue'? Are they nuts? It is not possible to have a convergence issue on an LCD TV.
    Next, I hope you realize that remote troubleshooting is definitely a case of GIGO - Garbage In, Garbage Out. And 'Kind of a red ghosting' doesn't provide much information. You've tried different inputs - a good move. Does the problem also appear with the menus? If it does not, the problem is definitely a main board issue. Otherwise I would suspect Tcon board.
    Above all, a picture is worth a thousand words.
    PlainBill
    • cajoeg
      Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
      by cajoeg
      Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
      The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
      02-10-2025, 04:01 PM
    • arnard
      Insignia NS-32L430A11 backlight issue
      by arnard
      I have a weird backlight issue on the above Insignia Plasma that I am coming up empty on researching.
      The display is darker on the left than on the right side of the screen. It uses 4 U shaped plasma tubes. I have had it apart deep enough to tell you that the tubes are bright as they should be at the electrode ends but dim as they get to and go around the bend.
      Since it is all 4 tubes it seems like it would be an inverter/backlight board but obviously can't be a blown up component as it does still somewhat work. I'm thinking low voltage but no idea where to go beyond...
      06-10-2023, 01:36 AM
    • rounin
      MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
      by rounin
      🛠 Original Issue
      ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
      04-19-2025, 01:18 AM
    • ugamazing
      by ugamazing
      12-17-2024, 07:05 PM
    • ahmarzo
      Acer laptop battery draining issue
      by ahmarzo
      Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
      Help me to diagnose this issue as there is no shortage in the inputs MOSFET
      08-02-2025, 06:39 AM
