Insigna NS-lcd37 no sound
  • truep
    • Aug 2010
    • 373
    Insignia NS-LCD37, Perfect picture but no sound. Tried all outputs, and the optical out. Nothing. Bad main board?
  • crepiduse
    • Nov 2010
    • 69
    Re: Insigna NS-lcd37 no sound
    I would check all connections first. Post pics of all boards, could be a Signal Output board, audio board (which is in the main board on that one I believe) or a bad connection to the output board. Post pics and model numbers of all boards inside.
    • truep
      • Aug 2010
      • 373
      I checked all connections and power supply voltages. Camera is down so no pictures. the main board has 2 numbers 782.26HA37-690E printed on the board, and 37HA37-69 on the barcode sticker. I think I have a bad main board, but there are two different panels on this TV I have the one that is not the LG-Philips. Chumwa or something like that. Anyone have a service manual that can tell me what board to order?
      • ygorsan
        by ygorsan
        🧩 Problem Summary:
        • I
        07-28-2025, 08:34 AM
      • JDC
        (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
        by JDC
        ONN 100012588
        Issue: No Power, Then Rebooting After Main Board Change
        Short answer: replace main board and power board
        Technical answer: replace main board and Q306 & Q307 on power board.
        Long answer:
        TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
      • mrautom8
        Samsung TV UN75H6350AFXZC main board schematics?
        by mrautom8
        Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
        Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
        While relay is on, all voltage rails are present and steady (scoped) on main board.
        I love a good logic puzzle but getting lost without any schematics.
        No shorts on ANY capacitor main board.
        Thermal camera shows 3.3V inductor getting warm instantly but...
        10-19-2025, 06:32 PM
