polaroid TLA-01911C white screen
  • =DanTheMan=
    • Dec 2010
    hi everyone I have this polaroid LCD that powers up with just a pure white screen. I disassembled the lcd panel and all 4 of the CCFLs are lit up fine so i know its not the backlight or inverter. The ribbon cable going to the LCD is tight so i know its not that. On this model the inverter and power supply are on the same board and there some bulged caps. Would replacing the caps on the power board most likely solve my problem or are there some on the receiver board i would need to replace as well. Any suggestions about this model?
  • PlainBill
    • Feb 2009
    • 7034
    Re: polaroid TLA-01911C white screen
    A white screen indicates a problem with the LCD panel or the main board. Still, replacing the bulging caps is the first order of business.
    Same old, same old. It's difficult to make reasonable suggestions without at least having a picture.
    PlainBill
    • 70JUDGE
      • Jul 2010
      • 81
      Here is something that might help you out.This says a white screen is caused by the T-Con board.I hope this helps.Thank You very much!
      Tyler
      http://www.fixya.com/support/r509388...shooting_guide
      • harp
        White screen repairs
        by harp
        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
        05-13-2024, 03:43 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • EazyBone
        Sharp LC-65Q620U White Screen
        by EazyBone
        Another TV topic!!
        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
        08-21-2024, 12:56 PM
      • hcinne
        Dell G15 ryzen edition black screen 2 amber 1 white
        by hcinne
        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
        07-23-2024, 07:56 AM
      • Chrissygizmo
        Panasonic TX-48CX350B backlights but white screen , blank screen
        by Chrissygizmo
        Hi all, I’ve got a problem I hope someone can help me fixi.
        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
        01-11-2025, 03:18 PM
