Sony KE-32TS2E - Dark screen / Green Haze
  • mushy408
    • Nov 2010
    • 9
    My problem is my Sony KE-32TS2E Plasma tv. Was given to me by a friend who's just upgraded to a 42" lcd. Tv has worked with no probs for a number of years.
    Anyways, I have the tv now. When I turn it on, the picture displays as normal for about 1 second then fades out to dark/greyish with green hue, then 'click' and the tv turns off. I could hear the sound no probs for the split second it was on. After checking the service manual, I've set about trying to repair it.
    I purchased a pair of boards from ebay (X & Y sustain boards) as they were the first 2 suspect parts (as suggested in the service manual)
    I replaced the X-sustain board - still same fault. Then I replaced the Y-sustain board and now I can turn the tv on and it will stay on until I switch it off.
    Only problem is the picture fault is still visible...
    So now I'm thinking the PSU board is at fault. I've checked the voltages from the PSU to the X & Y boards. Think I've found it...
    There should be 80v, 55v, GND & 5v coming out of the PSU...
    When I initially turn the TV on, the PSU outputs 80v, but then drops to 65v - this happens just as the screen starts dimming. The other voltages are spot on (I don't have an oscilliscope to check them properly)
    From what I read, this is a common fault with this set. I'd prefer to try and fix the PSU board before shelling out £100 for a new PSU.
    I've checked ALL the caps on the PSU, they all look fine. Are there any other specific parts I should be looking at? Maybe a weak mosfet? Dry solder joint?
    I will try and upload a picture of the screen when I get chance.
    ANY help greatly appreciated!
  • jimjoe123
    LCD TV Green/Pink screen problem
    by jimjoe123
    I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
    Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
    Then each time...
    02-23-2020, 01:29 AM
  • Nopy
    Sony KDL-55EX500 solid green screen
    by Nopy
    I have a Sony KDL-55EX500 which shows a solid green screen and I haven't been able to diagnose the problem. I was able to find a repair manual online and read a few forums on tv repair which pointed me towards it possibly being an issue with the power board or T-con board. Bad electrolytic capacitors seemed to be a common theme so I tried replacing all of the ones on on the power board, but that didn't fix it.
    My next step was disconnecting all of the cables and reconnecting them. That helped a bit, showing a normal screen most of the time, but still switches back to solid green...
    03-08-2022, 07:48 PM
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • String2016
    samsung np300e green screen
    by String2016
    I need help on this samung np300e laptop, laptop turns on but the display green screen samsung logo and no bootable device shows but all green, I have replaced good lvds cable and good screen still problem persist.anyone encounter this problem please help
    07-26-2025, 04:00 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
