Sharp Aquos LC-42D62U Display Output Problem
  • R_J
    • 9588
    Re: Sharp Aquos LC-42D62U Display Output Problem
    This might help
    • electronicsurplus
      • 210
      Just wanted to add: which may be helpful to someone
      I fix this problem 99% of the time by simply reflowing the ICs on the Main Board and Viola Perfect picture. Just completed 2 today. Does not take a bunch of heat
      If you have any liquid flux handy used around the IC pins and heat until the flux is gone and you should be all set
      Works well for me
      Aimee
      This Forum absolutely the best and, the most helpful forum I have ever found anywhere. thanks to all the fantastic members here
      Help keep these from the landfills
      • FrancescoV
        Onkyo HT-R390 no sound output, video output ok
        by FrancescoV
        Good morning everyone,
        I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
        The firmware reported is the following:
        M:1.00/11107BLP
        D:?.??/????????
        O:1.00/11107AL
        The DSP firmware given the question marks seems corrupt.
        On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
        05-11-2025, 02:59 AM
      • scubacamper
        Sharp Aquos LC-70C6400U Half Screen Dark
        by scubacamper
        I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
        Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
        when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
        05-03-2025, 12:19 PM
      • sefoster
        Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
        by sefoster
        I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
        11-20-2022, 09:29 AM
      • jonah1024
        Sharp Aquos LC-40UG7252E LCD TV burn in?
        by jonah1024
        Hello!
        I'm a few days old into this TV screens repair universe so please bear with me.
        Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
        - I did the classic unplug and hold power button to discharge the caps but it didn't help.
        - I did a factory reset as well...
        07-16-2024, 04:23 AM
      • AustinComputerDoctor
        Sharp CC-60LE640U - after mainboard replacement, backlite turns on -- but cannot update firmware / see menu
        by AustinComputerDoctor
        I am looking / wondering if anyone knows where a good firmware download link is for a LC-60LE640U, the sharp support sight says the screen is archived but offers no links.
        I see backlite is active,
        but I cannot get the screen to return back to menus , etc
        This is all after replacing the mainboard...
        any assistance is greatly appreciated.
        03-25-2024, 12:43 PM
