LCD Not Working
--- begin sig file ---
--- end sig file --- -
Re: LCD Not Working
PS. Despite the ".ca" both companies ship their caps from the USA. So, Canadian customs, as per usual, might delay the package. And it is holiday season so it make take a bit longer to get it than "normal".--- begin sig file ---
--- end sig file ---Comment
Re: LCD Not Working
Ay! LOL Where are you located. I'm in Southern Ontario.
Well I went through Mouser. Cuz I have an account there already. It's hit and miss. So Didikey is next try. Mouser ships to me via USPS for $8.
OK Caps round two!
BTW what does "low ESR" mean? At mouser I could just select "low ESR" but at DigiKey the filters are set up different.
MenessisLast edited by Menessis; 12-01-2010, 07:55 PM.Comment
Re: LCD Not Working
ESR = equivalent series resistance (ohms). Some datasheets refer to it as impedance as well.
If mouser is $8 shipping and you have an account there, it might be easier for you to stick with mouser.--- begin sig file ---
Re: LCD Not Working
OK are you willing to look over my list agian?
DigiKey
1 1 493-1603-ND CAP 22UF 50V ELECT HE RADIAL 0 0.35000 $0.35
2 1 P11232-ND CAP 47UF 35V ELECT FC RADIAL 0 0.37000 $0.37
3 3 P12353-ND CAP 1000UF 10V ELECT FM RADIAL 0 0.75000 $2.25
4 3 P12366-ND CAP 1000UF 16V ELECT FM RADIAL 0 0.74000 $2.22
5 1 P12368-ND CAP 1500UF 16V ELECT FM RADIAL 0 0.94000 $0.94
6 4 P10301-ND CAP 470UF 35V ELECT FC RADIAL 0 0.77000 $3.08
Subtotal $9.21
Shipping $8.00
I hope it "Saves" my list over there.
MenessisComment
Re: LCD Not Working
I suggest P12927-ND (Panasonic FM) for the 22uF 50V cap.
For cap #6, Normally, I would suggest the 470uF 35V FM series (versus FC), but I see the FM has zero stock. So FC is a suitable choice.2 1 P11232-ND CAP 47UF 35V ELECT FC RADIAL 0 0.37000 $0.37
6 4 P10301-ND CAP 470UF 35V ELECT FC RADIAL 0--- begin sig file ---
Re: LCD Not Working
I also checked United Chemi-con and Nichicon low ESR 470uF 35V caps and digikey also have none of them in stock. Badcaps.net doesn't sell 470uF 35V Rubycons.
Perhaps some big company needed a lot of 470uF 35V caps for an upcoming xmas product?--- begin sig file ---
Re: LCD Not Working
Progress !
OK I put in all the caps and put it together. Stood back and plugged her in ready to yank the plug.
Red light....pushed the power button.........green light, screen lit up.
Buttttttttt then I tapped the "menu" button and nothing happened, same goes for the "source" button.
So now what???Comment
Re: LCD Not Working
Double check all your connections between the boards. These connectors can be fragile and may not be securely in place.
It would help if you could post an "overall picture" with everything connected (using manage attachments and not inline) so we can see the "big picture".
Then we need a close up picture of each individual board (including the power board with the new caps).--- begin sig file ---
Re: LCD Not Working
Wellllllllll.....the power supply is inside. Then you have to put the back on and then plug in the board that handles all the inputs. I grab a pic of the "input board" it's easy. And check the connections of course.
What a crappy design.
MenessisComment
Re: LCD Not Working
Hey guess what......Opened up the "input board" cover. The one cable that is a "zero insertion" type was not in all the way.....
I've got menus now. Just have to plug in a source and see what happens.
OK had some supper...plugged in my camera for a source and WALLA! It works. Just amazing.
You guys are great. So now I will attempt that Sharp for my buddy.
MenessisLast edited by Menessis; 12-06-2010, 08:23 PM.Comment
by TyMercerApologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
by MMH3Hello,
i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
Never ever i experienced problems with that.
Now i have one 5050sff machine, where this jumper isnt working at all.
I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
The history of the machine is that i used it in my office... -
by DynaxSCHi,
I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
The board is generally working now, all PCIe ports are working, Windows installs normally.
However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA... -
by obelix24Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID and after replacing UT610 it was working but here i'm not able to find anything related to... -
by hopkokHi masters, I need your help.
I am working on Lenovo Legion 16ITHg6
Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
Power LED is not working as well, power button working well.
UI26 ??? is there any firmware too? Powered by +3VALW_AG.
Motherboard...05-04-2025, 09:35 AM - Loading...
