Looking for this Component
  • chuckjuggernaut
    • Sep 2023
    • 10
    can anybody tell me what this component is and a similar from other brand???
    cannot find a source
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4302
    • Italy - Milan
    Re: Looking for this Component
    it seems a power resistor 20ohm 5w
    • chuckjuggernaut
      • Sep 2023
      • 10
      Hi @Davi.p thx man,... is it possible to solder 2x power 10ohm resistor together?
      can not finde a supplier for this component
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4302
        • Italy - Milan
        3x2w in parallel, the most near value to 60ohm, have you checked Conrad in Germany? RS, Distrelec, Farnell..
        • chuckjuggernaut
          • Sep 2023
          • 10
          Yes,.. Unfortunately there is no more conrad in Germany, they have closed all branches. Maybe on reichelt, i will try it there,...
          Isn't it better to use 2x 5w 10 ohms in series or does that cause problems?
          The device is an LG Plasma TV.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4302
            • Italy - Milan
            No, Conrad still exists, no more shops on the road but all there in the web...
            i think you haven't room for 2x 5w..
            • lol999
              Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
              by lol999
              Motherboard after starting show Q code 00.
              No shorts on any rail ( at last I can't finde any)
              All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
              Nothing get hot, PSU starting, all lights came ON....
              One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
              After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
              This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
              01-21-2024, 02:25 PM
            • jaglion19
              GI5CNXA MB v1.0 monster Abra A5 V13.3 HM370 CHANGE
              by jaglion19
              GI5CNXA MB v1.0 monster Abra A5 V13.3 SR40B HM370
              Good luck to everyone, my problem is as follows. I have a la-f841p rev 1a motherboard, which occasionally gives a blue screen due to the processor running the motherboard. I installed the southern chipset of this motherboard into the short-circuited device with Monster Abra A5 v13.3 GI5CNXA MB v1.0. When I trigger the monster device, it goes up to 230mah and turns it off again. I have tried many of these devices before, but I did not get any results. They definitely want a brand new chipset. Other models do not have this problem,...
              04-10-2025, 06:59 AM
            • electrono
              Bios unlock for Asus Vivobook X513EA
              by electrono
              The situation is as follows:
              I set a supervisor password for my bios and forgot it because my laptop boots directly into Windows. So apparently there is no need to remember the password, my brain thought, so here I am
              System Specs:
              • Operating System: Windows 11 Pro 64-bit (10.0, Build 26100) (26100.ge_release.240331-1435) (Updated from original Windows 11 Home to 11 Pro using a key)
              • System Manufacturer: ASUSTeK COMPUTER INC.
              • System Model: VivoBook_ASUSLaptop X513EA_K513EA
              • BIOS: X513EA.310 (Type: UEFI)
              • Processor: 11th generation Intel(R)
              01-11-2025, 02:59 PM
            • hima_96
              Dell Latitude 5285 Onboard RAM Upgrade ?
              by hima_96
              Hello Everyone , I own a dell Latitude 5285 2in1 with 7th gen core i3 , Unfortunately the ram in this tablet PC is on board chips. the original ram on the device is 4G (1GB) for each chip in the motherboard 4× Skhynix (H9CCNNN8GTAL-ARNUD 752A)
              I made a small research I found in the Chinese market the (Skhynix H9CCNNNCLTML ARNUD626A) Chip
              which is 4G DDR3L Chip. I bought 4 to upgrade my tablet PC to 16GB.
              Can I just reball the new chips and upgrade the ram?
              or do I need to remove or add some transistors or maybe bios mod , I saw the boardview and didn't...
              11-12-2024, 06:47 PM
            • LatinMcG
              Huawei KLVL-W58W Bios Pwd
              by LatinMcG
              ive tried at least 15 variations trying to bypass setup password.
              also have boot password which is known 12345.. but cant enter setup.
              anyone can get Chinafix file?
              or taobao asking for 10 yen (i can pay but dont have acc)
              MateBook14 KLVL-W58W (53013PBU)
              W56W should work and KLVL-WFE9Q KLVL-W76W
              nb3800_mb_v3
              Thanks!...
              02-04-2023, 11:52 AM
