Vestel Based JVC no picture, leds on
  • nick4275
    • Nov 2023
    • 4
    Hoping someone has troden this path before !
    I'm looking at a JVC LT-39c790 - a vestel based unit.
    So, the remote turns it on, led's light up but no picture at all.
    I have a spare mainboard, so I know its not that. The PSU seems ok too.
    On the AUO T-Con I've got 16v on HAVDD_H but nothing on HAVDD_L - which I'm assuming should also be 16v ?
    So, Ive resorted to testing eveything I can on the board as I can't find any schemas for it (AUO 39T15 C04 Ctrl Bd) and I think I've found a diode gone short. it marked D005 on the board and E1 on the package but I've no clue as to whether this is a standard diode or a zener etc.
    Any pointers greatly received.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Vestel Based JVC no picture, leds on
    Regarding the diode maybe remove it or lift one side and re test it for a short.
    • lotas
      • Jan 2016
      • 4874
      • Russia
      E1 - MMSZ5231B (Zener diode at 5.1v)
      • nick4275
        • Nov 2023
        • 4
        Thanks for the responses. Although I think Ive been "off the tools" too long. It wasn't the diode, I forgot to unplug the logic board before testing !
        So ignore what I said previously ! - This is what's happening........
        The AUO 39T15 CO4 Ctrl Bd has virtually no voltages on it apart from the incoming 12v from the logic board. If I unplug the daughter board ( 39T15 SO 8 XL) then AVDD, VGH and VGL return to normal although VCOM is only showing 1.9V
        Long shot I know but does anyone have a clue where to start !
        Are there no schemas for these AUO boards at all ?
        TIA
        • zwarder
          • Oct 2013
          • 46
          • United Kingdom
          Have you tired disconnect one side of the panel to see which side may be bad?
          Then block ckv lines with tape
          • Tr0ll
            by Tr0ll
            Original T-con:
            First replacement T-con:
            10-07-2023, 07:48 PM
          • JJAAMM
            by JJAAMM
            Problem
            07-06-2023, 06:01 AM
          • freccia
            Vestel 42 inch VES420UNDL no picture, backlight ok, sound ok
            by freccia
            I have a Finlux/Vestel Led Tv with the following fault and cannot reason from where the fault is. Fault is:
            Sound ok, Backlight ok, Picture nothing but colour vertical lines. power supply vestel 17 IPS 71, main board 17MB82S
            Checked 12V on tcon on fuse ok.
            Checked 12v and 24v on power supply ok.
            Volume works. removed l left ribbon cable no picture white on half, and same with right one.
            Any idea from where I can start please?
            Any help appreciated please....
            01-09-2022, 05:14 AM
          • TR103
            by TR103
            - it keeps rebooting
            01-22-2025, 04:12 PM
          • Pipolups
            Corsair K70 LUX RGB dying LEDs
            by Pipolups
            Hi there !
            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
            10-08-2024, 11:58 AM
