Original RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008
  • tech9pc
    • Sep 2021
    • 50
    Hi does anyone have firmware for RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008. It is not available nowhere on the internet.
    I got a Version 1 CV3458H-A, 7.T3458HA1000.0003 off ebay for 30.00 and popped it in and board works but about every 20 or 30 minutes tv loses input signal and have to flip HDMI source than back to get picture up again. Probably from not being the same board as original which had lost its HDMI ports signals. I baked the board in oven but have not tried to put back in yet.
    Is there a way I could dump the original mainboard 7.T3458HA1000.0008 image to a usb stick and try flashing it onto the 7.T3458HA1000.0003 mainboard I have in the tv now?
    Original Board BD_CV3458H_A_10
    Firmware: 7.T3458HA1000.0008
    C/N: SU-CU-20180601
    Panel LC650RU1A
    Here is link to shopjimmy original board that I am hoping can flash onto the one I got off ebay that has an older 7.T3458HA1000.0003 firmware image on it
    https://www.shopjimmy.com/rca-main-b...on-2-see-note/
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ygorsan
    by ygorsan
    🧩 Problem Summary:
    • I
    07-28-2025, 08:34 AM
  • jb_Bak
    by jb_Bak
    CN6401
    Pin 01 NC
    Pin 02 NC
    Pin 03 "BL_ON": 0V
    Pin 04 "N/C"
    Pin 05 "STBY 3.3V": 3.5V
    Pin 06 "GND": N/C
    Pin 07 "AC_OFF"...
    09-27-2021, 04:52 PM
  • JDC
    by JDC
    ONN 100012588
    Long answer:
    07-15-2022, 07:39 AM
  • mrautom8
    Samsung TV UN75H6350AFXZC main board schematics?
    by mrautom8
    Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
    Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
    While relay is on, all voltage rails are present and steady (scoped) on main board.
    I love a good logic puzzle but getting lost without any schematics.
    No shorts on ANY capacitor main board.
    Thermal camera shows 3.3V inductor getting warm instantly but...
    10-19-2025, 06:32 PM
