Samsung UN55MU7000F No Power No Standby LED
  • ojoil
    • Apr 2024
    • 5
    I read through this post:
    https://www.badcaps.net/forum/troubl...no-power/page2
    It seems like my tv is exhibiting similar symptoms. I have backlight when only the power supply is connected, but I didn't test much further.
    The main board is slightly different (BN94-12402R) although it is stamped the exact same...
    Board is stamped:
    MODEL: KANT_M_BUILT_IN
    CODE: BN41-02568B
    MODEL: BN41-02568
    I wonder if flashing the EEPROM will work on my board as well? If so, is someone able to provide the flash file for for me?
    Thanks!!
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Post your original dump from 25Q40 here, I’ll fix it.
    • ojoil
      • Apr 2024
      • 5
      Hi lotas here's the dump! Thanks
      • lotas
        • Jan 2016
        • 4708
        • Russia
        Try.
        • ojoil
          • Apr 2024
          • 5
          when trying to write the status registers S9/QE is greyed out in Asprogrammer so register 2 is set to 40 instead of 42. Will that be an issue?
          • lotas
            • Jan 2016
            • 4708
            • Russia
            If there is a problem, change the program to NeoProgrammer V2.2.0.10
            In Asprogrammer the problem is in these status reg.
            • ojoil
              • Apr 2024
              • 5
              Ok neoprogrammer worked, but same symptoms.
              I will remove the IC and attempt again:
              Is this the correct sequence?
              -Clear flash
              -write 0 to status registers
              -write fixed flash
              -write 0x88 and 0x42 to status
              Thanks for your help!
              • lotas
                • Jan 2016
                • 4708
                • Russia
                1. First you need to delete all status registers (uncheck all the boxes and click "Write")
                2. Erase the chip.
                3. Write down the corrected dump and check what was written down.
                4. Set the status register (0x88, 0x42), check the boxes and click "Write"
                5. Everything is ready, solder the chip in place....​
                • ojoil
                  • Apr 2024
                  • 5
                  That worked! Thanks again for your help
                  • lotas
                    • Jan 2016
                    • 4708
                    • Russia
                    Ok!
                      09-07-2024, 05:50 AM
                    • tvguy12012012120
                      by tvguy12012012120
                      02-07-2025, 05:13 PM
                    • ChristianBr01
                      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                      by ChristianBr01
                      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                      04-23-2025, 01:48 AM
                    • Kaar3l
                      Samsung QLED QE65Q7FNAT only standby light
                      by Kaar3l
                      TV: Samsung QLED QE65Q7FNAT
                      PSU: BN4400940A
                      MB: BN94-12832K
                      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                      09-24-2024, 01:35 PM
                      09-06-2024, 11:40 PM
