Samsung UN60EH6000 wont come on after lightning strike.
This topic has been answered.
  • karthur
    replied
    After much searching, I finally found a datasheet on this component. This component is made by "Diodes Incorporated". This is a voltage regulator. A link to the data sheet is here.
    https://cdn.badcaps-static.com/pdfs/...fca50db500.pdf
Name:	DII AP1117.png
  • karthur
    replied
    I thought you said IC601 was a double diode. I have been treating and testing it as such.
    Refer to post#16 above.
  • Davi.p
    replied
    IC601 stands for Integrated Circuit 601, why you tell about anode, cathode?
  • karthur
    replied
    When I tested the IC601, I get a reading with the "+" probe on the anode and "-" on the cathode. When I reverse the leads, shouldn't this now read "0" for a good diode? I get a reading >0 when I do this for both legs. Does this not mean the diode is faulty?
    I tested IC601, IC602 and IC204, To me all three seem to be faulty. Am I testing these wrong?
Name:	Good or Bad.png
  • Davi.p
    replied
    probably diodes are a previous fault..
  • karthur
    replied
    Originally posted by lotas
    These are protective diodes and they are located at the AV signal input; if something was connected during lightning, then the discharge passed through this input and could kill the processor.
    Which ones are you referring too? If you are talking about the D407 and D409 that I found burned, these seem to be diodes and upon more checking are not good. One is totally open in either direction.
    These diodes are close to the RCA input jacks on the board. The only port that was connected during the strike was HDMI1.
  • lotas
    replied
  • Davi.p
    replied
    those two are double diodes, check them in diode mode,
    no power on board..
    test ic601 as the other ones, thus in volt on the tab, if it's 3,3v is ok, if no short (0v) on the diodes then ic901 reprogram..
  • karthur
    replied
    I did check the D407 and D409, but not 100% sure what they should test. They were 0v on one leg and 3.5v on the other (See post #15). I tested IC601 on the board with power on it and without power diode mode. Attached are the results.
Name:	IC602 Readings.png
    I also tested some of the other voltage regulators that looked similar in diode mode. The readings were .3 and .6 one one and .5 and .6 on another one. Not really sure if I am doing this right or not.
  • Davi.p
    replied
    1) test as the other ones 2) test them..
  • karthur
    replied
    Do I need to remove the IC601 from the board to test it? Do you think the D407 and D409 are good?
  • Davi.p
    replied
    Sorry not IC206 but IC601, to the right bottom, those two are double diodes, check them in diode mode, the ic901 must not be changed but only programmed, i don't have the dump..
  • karthur
    replied
    Here is what I got when I checked IC202 and IC204. IC 202 was 3.3V on the pin 1. IC204 was 1.5v on the tab. I could not find IC206. If you found IC206, can you point to it on the board?
    When looking for the IC206, I noticed a couple "Burned" components. These are D407 and D409. I take it these are voltage regulators. Here are the readings I get on them. Are these OK?
    "IF" I do need a new flash for the IC901, where do I get the file to flash on it?
Name:	D407_D409 Readings.png
  • Davi.p
    replied
    Check the regulators IC204 (1,5v on the tab), IC202 (??V), IC206 (3,3v on the tab). This chassis really sucks, the main flash ic is integrated to the SOC!!
    if regulators appears ok it must be reprogrammed the SPI flash IC..
  • karthur
    replied
    Here is a picture of the back of the main board. Also the measurements you asked for.
    Click image for larger version Name:	Back of Main Board.jpg Views:	0 Size:	3.08 MB ID:	3154223
    Click image for larger version Name:	Main Board Voltage Readings.png Views:	0 Size:	563.0 KB ID:	3154221
  • Davi.p
    replied
    i think you must reprogram IC901, first however you must check some tensions, can you photograph the back of main board? Check voltage on ic905 pins, and on every mb coil except those 4 grouped..
  • karthur
    replied
    Picture of the T-Con Board
Name:	Timing Control Board.jpg
  • karthur
    replied
    Picture of the main board.
Name:	Main Video Board.jpg
  • karthur
    replied
    Originally posted by EazyBone
    Well if we don't have pictures of PSU main etc and then the pin connectors from board to board with the legend, that would help. Also lightning (if it was) will destroy PSU or main generally I would think. How do you know it's lightning strike? Did other things in your house fry or just the tv?
    Yea. There was some other things in the house that would not work after the lightning strike (Alarm system, HVAC unit, Garage door opener and one refrigerator). I did check the connecters on the PS board in my original post, but I guess they dont mean much unless you know what they should be. My bad.
    I DO NOT have a red standby light and I initially suspected the PS board, but after checking the pins, I thought the PS was good.... maybe not.
    Below are the values I got along with the values printed on the board.
    On the power supply board, 14pin connector:
    1 :12.7 Vdc (PWM_D1M 13v)
    3 :12.7 (B13V 13v)
    5 :12.7 (BLU_on/off Vamp)
    7 :12.7 (GND Vamp)
    9 :0 (GND)
    11 :5. (A5v)
    13 :5. (Power_on/off 5v)
    Here is a full image of the PS board
Name:	PS_ Connections_1.jpg
  • EazyBone
    replied
  • Bardou Kari
    HP EliteBook 840 G6 – no power after lightning strike
    by Bardou Kari
    I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
    – Charger is OK and 19V is present at the motherboard.
    – No charging LED, no fan, no reaction.
    – I don’t see any 3.3V or 5V near the coils.
    – Battery is unplugged.
    – I’m new to board repair but can use a multimeter.
    I added a clear photo of the board.
    Any idea where to start or what to check next?
    Thanks a lot for your help!...
    07-01-2025, 10:45 AM
  • SluggerB
    Panasonic TH-50PX80 killed by lightning strike, help me save her!
    by SluggerB
    Yes it's a 17 year old Panasonic plasma!
    I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
    06-04-2025, 07:02 PM
  • MrCreosote
    Lightning Strike: 55" TV dead: is display panel OK?
    by MrCreosote
    THE LIGHTNING:
    This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
    Very close and probably a very strong EMP.
    THE TV:
    No standby LED. Some voltage from PSB (not totally dead).
    But found a kit of ALL 4 circuit boards for $55.
    At first thought, this will fix my TV.
    But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
    08-16-2021, 10:27 PM
  • pbig
    advices for repairing Sony Bravia 32EX600 after lightning strike
    by pbig
    hi everyone,
    my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
    On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
    - the 450V/150uF capacitor voltage when plugged is normal at 394V
    - from connector CN6150 (15 poles)
    STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
    06-28-2023, 02:43 AM
  • pfl
    ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
    by pfl
    Hello Everyone.
    This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
    It consists in :
    • a power board were the full H bridge class D amplifier and main power rails are located
    • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
    Power rails are ok.
    human interface is working fine
    Input levels are...
    01-23-2024, 10:21 AM
