Sony Bravia 65x900F BL On but not picture
  • lmcancu
    • Oct 2009
    • 158
    Re: Sony Bravia 65x900F BL On but not picture
    I need to disconnect LED driver board from Power supply board too?
    Do I jumper STDBY 3.3 with power on, and also STBDY 3.3 with TCON ON?
    • Diah
      • Feb 2013
      • 6424
      doesn't matter if u disconnected or not it will be out since u only connect STDBY 3.3 with power on, and also STBDY 3.3 with TCON ON
      • lmcancu
        • Oct 2009
        • 158
        Ok thanks! That video was misleading. So I connected as you said and I could see no picture with a flash light. I then connected the BL_On to 3.3 (also Tcon-on, and Power on) with the LED board connected to the power board. I only see the backlight on and no picture. So you think it may be the buffer boards right? I will need to take the stand off and put the display flat on a table to remove the metal covering. I will do that tonight and upload the pictures
        • Diah
          • Feb 2013
          • 6424
          on the panel buffer boards, you will find on each side at the middle ribbon cable like letter U , called U ribbon,,, if you have this on the boards,,, need to disconnect only one side on each time and turn on after you put all cable of MB back in place as original..
          if your screen stay as it before not image or white 3/4 screen... mean your T-CON bad
          • lmcancu
            • Oct 2009
            • 158
            For my understanding, the buffer boards are under that metal shield below the t-con ribbon cables in the attached picture right? If I just disconnect one of the ribbon cables from the t-con board, would that do the same test?
            • Diah
              • Feb 2013
              • 6424
              yes under the metal, remove it after remove the speaker..
              No, the U ribbon test in case you have them on panel boards more effective than one ribbon from t-con... because it will load the panel as 3/4 while the t-con ribbon disconnection will be 1/2
              • lmcancu
                • Oct 2009
                • 158
                #27
                I didn't take the metal off yet, but looked online for a video that had a picture of the buffer boards. I don't see any U ribbons in this picture. This is the left buffer board I think
                • Diah
                  • Feb 2013
                  • 6424
                  are you always so in yours life??? dont have trust on yours self and other ??????
                  what are under his fucking hand in photo.... this is fucking u ribbon.... this is my last post.... sorry
                  • lmcancu
                    • Oct 2009
                    • 158
                    #29
                    Sorry, it was not that I didn't trust. It was more a question of where the U ribbon was. I was looking for the shape of the U and I coudldn't see it in the picture. I know that you have helped a lot of people in this forum, including me before, and I really appreciate your help!
                    How would I detach the ribbon?
                    • lmcancu
                      • Oct 2009
                      • 158
                      #30
                      Ok I see it I think! Those two white connectors hold the ribbon cables and the U shape is between those two connectors. Sorry for being dumb! I will check it tonight and let you know. And even if this is your last post, I really appreciate all your help!!
                      • lmcancu
                        • Oct 2009
                        • 158
                        #31
                        Hi Diah, screen stayed like before, only backlight on each side. So thank you for the diagnosis, and I will try to find a t-con board to replace this defective one.
                        Please see picture on my buffer board and the U-ribbon I disconnected.
                        Thanks again!
                        • lmcancu
                          • Oct 2009
                          • 158
                          #32
                          Question on the TCON part: The label on it says the following:
                          V40846J810M9V and LMY650FF01-A
                          I found a tcon board for sale with the part number:
                          V40846M9F04V0 and LMY650FF01-A
                          Are these the same boards except mine is the J version, and this one is the M version? Functionally they are the same but perhaps an improved version?
                          Seller indicates that they are all the same parts:
                          MANUFACTURER: Sony
                          PART NUMBER: LJ94-40846M
                          ALSO KNOWN AS:
                          40846M
                          LMY650FF01-A
                          E88441
                          TYPE: T-Con Board, LCD Controller, Control Board, CTRL Board, Timing Control
                          KNOWN MODELS:
                          Sony XBR-65X900F
                          Sony XBR65X900F
                          • lmcancu
                            • Oct 2009
                            • 158
                            #33
                            Fixed! Replaced with new T-CON and TV is alive again.
                            Thanks again!
                            • iglitare
                              by iglitare
                              09-04-2025, 07:13 AM
                            • CyberPhoenix
                              Issue with picture quality of Sony bravia TV
                              by CyberPhoenix
                              Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                              01-22-2024, 02:08 AM
                            • Spc.
                              Sony Bravia KD43XF7596BAEP - Android no picture
                              by Spc.
                              Greetings everyone.
                              I also have Sony Bravia, model:
                              Sony Bravia KD43XF7596BAEP - Android.
                              What happend is that image dissapeared while we were watching tv.
                              Diagnostics:
                              1. TV turns on, no errors
                              2. Backlight turs on, no errors
                              3. Power indicator turns on, white color, no errors
                              4. Menu works on android, you can hear sound while switching channels
                              5. Volume up and down works via TV remote and via buttons
                              6. Tunner works, HEVC / MPEG-4 decoder works
                              7. I get audio from channels
                              8. No picture is present,...
                              05-19-2022, 04:28 AM
                            • KYBOSH
                              Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
                              by KYBOSH
                              Previous owner said TV just went blank one day.
                              They attempted to open the back panel and yanked the power connector off the power supply in the meantime.
                              Easily fixed that and got the TV to turn on. Backlights come one with everything connected. Good Sign.
                              The mainboard shows signs of life (red light on digital audio out is on) but that's about it. Good Sign.
                              There is not blinking LED and the most importantly there is LED response and sound when I press the MENU button on remote control. GREAT Sign.
                              I just downloaded the Sony KD-75X7800F Service Manual and...
                              11-19-2024, 10:12 AM
                            • Daren87
                              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                              by Daren87
                              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                              08-13-2023, 03:25 PM
