tv hisense 43" 2023
  • pillola
    • Dec 2011
    • 15
    • italia
    tv hisense 43" 2023
    Greetings to all of you!
    motherboard model RSAG7.820.12363/ROH
    THE N901 CONTROL CHIP HAS BLOWN....SOT23 6 PIN!
    Does anyone know what model this is?
    searched everywhere for 2 days without finding anything.......
    smd marked Vtb pB1 43 ????
  • pillola
    • Dec 2011
    • 15
    • italia
    Re: tv hisense 43" 2023
    smd marked Vtb pB1 43 ???? [/ATTACH]
    • Diah
      • Feb 2013
      • 6376
      are you kidding.... no need to draw diagram. show us with clear pictures of the parts. from top side and downside of the boards... its location will tell what its and for which purpose
      • pillola
        • Dec 2011
        • 15
        • italia
        no I'm not joking.........I have already written the type of board above,,,,,,,I just want to know what type of SOT23-6 chip manages the primary of the transformer,, ,,,,,after that I have everything I need!!!!
        :sculacciare:
        • pillola
          • Dec 2011
          • 15
          • italia
          I found the electronic diagram on the motherboard,,,,,I just need to solder the right chip...so as not to make mistakes!!
          • pillola
            • Dec 2011
            • 15
            • italia
            all the components that are mounted around the chip are all ok....from the mosfet, to the fast diodes, resistors and capacitances, but the chip is short circuited.......and I can't find exactly which model it is......must be a Chinese model similar to the ncp1251 as pinout
            • lotas
              • Jan 2016
              • 4620
              • Russia
              N901 - ld5537b1gl
              • pillola
                • Dec 2011
                • 15
                • italia
                thank you so much dear LOTAS...............now I can continue with more confidence!!!!!
                have a nice days dear friend!!!!!!!!!!!!
                • pillola
                  • Dec 2011
                  • 15
                  • italia
                  lotas ........you are a true friend !!!!
                  number1
                  • pillola
                    • Dec 2011
                    • 15
                    • italia
                    dear lotas while you're at it.. could you please send me the link where to get the complete mother board diagram?
                    thanks again !!!!
                    • lotas
                      • Jan 2016
                      • 4620
                      • Russia
                      But this circuit is from RSAG7.820.10360
                      • pillola
                        • Dec 2011
                        • 15
                        • italia
                        :gruppo:
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4343
                          • Italy - Milan
                          how do you know it is blown if you still read all the marking?
                          city: lecco
                          country: lecco
                          planet: lecco?
                          • pillola
                            • Dec 2011
                            • 15
                            • italia
                            [QUOTE=Davi.p;1284346]how do you know it is blown if you still read all the marking?
                            the switching does not start and the voltage on the vcc pin drops to around 0v, then measuring between vcc and ov pin, I detect resistance of around 5 ohm.......
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4343
                              • Italy - Milan
                              if you test it in circuit it could also be a condenser / zener between vcc-gnd...
                              • pillola
                                pillola commented
                                Editing a comment
                                let me do .......iìm the winner!!!
                            • pillola
                              • Dec 2011
                              • 15
                              • italia
ID:	3165068 every thin Click image for larger version
ID:	3165069 ​g fine!!! Click image for larger version
                              • pillola
                                • Dec 2011
                                • 15
                                • italia
                                thanks so much to Lotas.... now smart tv work very well...and replace the old sambung plasma tv , of about 20 kg !!!!!!!!!
                                replace tl431,,pc817 optocoupler and ld5631 primary switching regulator !!!!!!!!!!!!!
                                • pillola
                                  • Dec 2011
                                  • 15
                                  • italia
ID:	3165073 ok !!!!!!!!!!!!!!!!!!!!!!​
                                  • lotas
                                    • Jan 2016
                                    • 4620
                                    • Russia
                                    Congratulations on your renovation!
                                    • pillola
                                      pillola commented
                                      Editing a comment
                                      I had to be patient for the chip....then I realized that the 12 volt was fluctuating.. and I had to change the 817 and to be safe, tl 431!!
                                      happy Holidays!!!
                                  • lotas
                                    • Jan 2016
                                    • 4620
                                    • Russia
                                    Thank you! Happy holidays to you too! And with a working TV.
                                    • Coolgoodman
                                      Faulty Hisense 85Q6NAU TV
                                      by Coolgoodman
                                      85” Hisense TV
                                      Greetings,
                                      Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                      Dear TV technicians of forum, I hope this message finds you well.
                                      I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                      I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                      07-24-2025, 03:02 AM
                                    • ShahZaib Ghumman
                                      Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                      by ShahZaib Ghumman
                                      Hey folks,
                                      I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                      A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                      So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                      03-25-2025, 10:59 PM
                                    • nono34
                                      Hisense stuck in Colors cycle like test pattern.
                                      by nono34
                                      I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                      I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                      10-24-2024, 04:31 PM
                                    • DoubleBogey817
                                      HISENSE 65H6510G (13 AUG 2020) - POWER ISSUES
                                      by DoubleBogey817
                                      HISENSE 65H6510G (13 AUGUST 2020)
                                      When powered on, initial splash screen (HISENSE ANDROID TV) displays for a few seconds then power shuts off. Tried updating firmware with USB flash drive (can't find 4GB drive but did format larger drive in FAT32) with no luck. Flash drive would be accessed but would never get to the update process. I have ordered a board (RSAG7.820.7911/ROH, PART# 242585) from eBay which will arrive in a few days. Does anyone have any input of whether I am chasing down the right trail or should I be trying something else? I appreciate your time and wish to say thank...
                                      02-16-2024, 10:58 PM
                                    • Track4207
                                      Hisense H50N5300UK reboots when showing full red images
                                      by Track4207
                                      Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
                                      What happens:
                                      • TV appears to operate normally, for an indefinite amount of time until a problem image appears
                                      • The problem image is displayed very briefly, then the
                                      08-30-2023, 11:58 AM
