LG 55UL6200 that suddenly will not power on
  • PhakeJake
    • Oct 2023
    • US
    Hi folks!
    I was hoping you could help me identify my issue with my TV, or point me in the direction of useful information. From my original research I thought it was the power board, so I bought one from ShopJimmy, but after I installed it the problem persists. I've looked around at a lot of proposed fixes and it's not clear what the right one might be.
    I have an LG 55UL6200. On 3/14/2023 it stopped turning on. The red indicator light comes on when the power button is pressed. On subsequent presses, the screen barely goes on for a few milliseconds, and the red light flashes three times. It goes on for such a short time that it took me a while to notice that it went on at all. All I can catch is a glimpse of the bar in the top left that indicates what input it is on, before it is back off. Most of the screen is black the entire time. I have tried all of the easy fixes, like unplugging the TV and holding down the power button, using different outlets or cords, and leaving it unplugged for multiple days.
    I read the LCD TV basic troubleshooting guide best I could, but honestly it's over my head. I've always had a small interest in electronics but I have no training. Only thing I could glean from it is perhaps it's the T-CON board.
    Thank you for any and all help you are able to provide!
  • Diah
    • Feb 2013
    • 6532
    Re: LG 55UL6200 that suddenly will not power on
    you have the led back light fault.
    • zamanmshah
      • Mar 2016
      • usa
      I agree with Diah, it is a backlight issue. My suggestion is to order the whole set of led back light. Should be about $30 - $40 on eBay but look for a US shipping or you have a long wait. Get the backlight for right TV make and model and be gentle with the removal of the screen, and the little pillars that hold the screen up. Many YouTube videos on replacement of backlight.
      Final note, these LCDs are meant for non-repair so be extra gentle with removing the back cover clips.
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • lapfix
        HP OMEN NO power no light
        by lapfix
        HP OMEN : DAG35DMBAD0
        NO power ,no short ,no corrusion
        Consumption : when charger plg in = 0.004 amp
        Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
        when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
        No light at power button led
        All coils resistances :
        Pl 2001 =3v measured with kohm.
        pl 2004 = 5v measured with kohm
        pl 6001 = 49.7ohm
        pl 4012 = vccsa = 24.4 ohm
        pl 3001 =...
        11-03-2025, 07:48 AM
      • russpall
        LG 39ln540v - red light flashes twice, no power to LED driver?
        by russpall
        Hi there,
        I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
        The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
        08-27-2024, 01:07 PM
        by sam_sam_sam
        03-31-2024, 02:12 PM
        Laptop computer that went completely dead no boot no power light no hard drive light
        by sam_sam_sam
        See pictures for type of laptop computer
        I checked switching power supply brick 19.2 volts multi meter only
        No booting without switching power supply connected
        Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
        What the heck is going on here...
        04-04-2025, 04:58 AM
