Problem solved. It was the motherboard in the TV that was broken, I replaced it with another.
Thanks to everyone who tried to help me :-)
EU55JS9000T black screen and sound good
So did you get to try a different cable? this new layout doesn't make things easier, we all look alike now, do I have to pick an avatar like some stupid game or sum shit or what?Leave a comment:
Re: EU55JS9000T black screen and sound good
Hello.
I was finally able to find another OCB of the same reference for a TV with a broken panel but in fact the problem is exactly the same, the backlight turns off immediately after plugging in the OCB. So my diagnosis was wrong.
So, taking into account the tests that I had already carried out, do you think that it is the motherboard in the TV, the T-Con card, the backlight control card, the power supply card ?
What a gas plant this TV design ;-(Leave a comment:
Yes it's a good idea but I haven't found any information on how to do this. I would like more details on the procedure for doing this.Leave a comment:
To do this, you need an eMMC programmer and know how to connect it, solder it via ISP and program it correctly, and if the eMMC chip is already dead, then replace it with a new one....Leave a comment:
Okay but I don't know how to flash eMMC. Never do that :-)Leave a comment:
This can happen if their software version is different, that is, spi flash, eeprom and eMMC must be the same version, if correctly, then the entire set must be flashed, including eMMC.Leave a comment:
Thank you lotas, I will try tomorrowLeave a comment:
the best thing you can do is to connect a pc to the debug port and see the log, other than this you can try to access service menu through debug port and do a service reset..Leave a comment:
Here I found dump OC eprom and spi from "48". Try it, maybe you'll get lucky.Leave a comment:
I have already checked the continuity of all the signals with a multimeter with the cable plugged in.
No problems detectedLeave a comment:
i watched better your block diagram, i see now the separation Ocb/back board, things short, i suspect bad ocb to tv connector solderings.. reflow them all with little new tin.. both ocb & tv sidesLeave a comment:
Here are the dumps of these CI.
A lot of 00 on the mainboard TV SPI.Leave a comment:
your document speaks about 2 spi roms, to be aware of which one to process..Leave a comment:
Here is the dump of the SPI flash of the OCB card.
Maybe one day it will be useful to someone on this forum.Attached FilesLeave a comment:
must to find a source of the content and rewrite it, not extract anythingLeave a comment:
ONE BOX CONNECT... are the heart of Video and Audio wave Signal... Main boards CPU just process it to feed Panel... if Video wave Zero value... screen remain black for ever. even with out Connect box. end.Leave a comment:
I can extract the contents of the spi but personally I won't know how to do anything with itLeave a comment:
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by totofGood morning.
I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
HVDD : 7,28... -
by AudezeI have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
Does... -
I also had corrosion/oxidation on the... -
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappearedI bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
- Loading...
