Toshiba 55u5766dg (Vestel)smart tv
  • rvh
    • Feb 2020
    • 9
    • Netherlands
    The tv is a Toshiba 55u5766dg, made by Vestel.
    Sound: yes
    Picture: no
    That is, when powering up the tv, the indicator leds starts blinking and at a certain moment during the booting, (let's say afer 3-4 seconds) the screen lights up and shows the Toshibo logo for a second, then the screen goes black until a short flash a couple of seconds later and the indicatorled turns green. The screen stays black: no backlight and no picture
    When a connect a harddiskrecorder playing a recorded media, there's sound but no screen. Even with a torch i dont see a screen. No backlight, no picture.
    Anyone an idea what could be the problem?
    As the tv is booting and there's sound, i assume it's not the software, but a faulty component or so?
    Enlighten me with your ideas! Thanks in advance
  • rvh
    • Feb 2020
    • 9
    • Netherlands
    Re: Toshiba (Vestel)smart tv
    Problem solved!
    Replaced a bad capacitor that was bulged on the powersupply: 92uF/100V.
    After that the backlight issue was solved.
    • nomoresonys
      • 12081
      • U.S.
      This could have been solved in 2 seconds had you posted a good clear picture of the powerboard. https://www.badcaps.net/forum/showthread.php?t=39740
      • rvh
        • Feb 2020
        • 9
        • Netherlands
        It's quite difficult to make pictures of the inside of a tv when you don't remove the screws to open the tv
        After opening the tv, i immediately saw the bulged capacitor so indeed it was a quit simple repair.
        I had no idea which parts were in the tv and suspected the tcon of backlight perhaps to be defective. Turns out it's the PSU and that i need to swap the backlights also as there's a blue glow over the leds.
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • jord4231
          Toshiba 37AV500A Regza TV good power supply no sound no picture
          by jord4231
          Hi Everyone,
          I'm working on a Toshiba 37AV500A Regza TV.
          The issue:
          TV was working picture and sound went out. Green stand by light stayed on, It will respond to the power button being pressed (goes in and out of standby)
          The TV will very intermittently work for around 40 mins then stop. This doesn't seem to matter if its hot/cold unplugged for a while etc.
          I checked the PSU voltages and everything looked good.
          No bulging caps or signs of heat.
          24v aud = 24.41v
          12v = 11.98v
          5v = 5.062
          p_o/f = Goes high...
          03-29-2022, 09:21 PM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
          09-06-2024, 05:27 AM
