LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
  • Seb932
    • Sep 2023
    • 23
    i'would like to fix my not working LG 49UB850V tv.
    Symptoms:
    -AC plugged in, Standby LED not working
    -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
    Checked already:
    -Powersupply Output in Standby => 3.5V ok
    -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
    Any suggestions what to check next?
    Thanks in advance!
  • nomoresonys
    • 12206
    • U.S.
    Re: LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
    Good focused straight on pictures of each board and one of the whole back as to see how everything is connected.
    • Seb932
      • Sep 2023
      • 23
      I've attached the requested pictures, hopefully sharpness & resolution is ok, otheriwse i need to use better camera.
      • nomoresonys
        • 12206
        • U.S.
        Easy things first, check over the solder joints on powerboard, reflow any that look suspicious, check all the resistors and diodes on top of the board, youtube is your friend for how to videos if needed, examples of bad solder joints there: https://www.google.com/search?client...h=599&dpr=1.09
        • Seb932
          • Sep 2023
          • 23
          Thanks for recommendation, will try to check and resolder suspicious joinst.
          • Seb932
            • Sep 2023
            • 23
            Have checked solderpoints, found some suspicious pins and resolderd it. Also have done some additional measurements.
            Started with IC3000, responsible for "power on" sequence
            If TV is switched on, the IC3000 enables the different voltage regulators. I've measured input signals (from IC3000) and output:
            POWER_ON/OFF1 => IC2304 5V => +5V_NORMAL OK
            POWER_ON/OFF2_1 => IC2301 3.3V => +3.3V_NORMAL OK
            POWER_ON/OFF2_2 => IC2302 2.5V => +2.5V_Normal OK
            POWER_ON/OFF2_3 => IC2303 1.5V => NOK PWM/rectangle signal with ~650kHz and 12V Peak
            POWER_ON/OFF2_3 => IC2300 1.0V => NOK PWM/rectangle signal with ~340kHz and 12V Peak
            POWER_ON/OFF2_4 => IC3409 1.2V => NOK PWM/rectangle signal with ~500kHz and 12V Peak
            Any further ideas?
            • Diah
              • Feb 2013
              • 6384
              you have much fault at LED BL
              • Seb932
                • Sep 2023
                • 23
                BL is fully functional. Tested by maual bridging SBY 3.5V to POWER_ON and DRV_ON on SMPS w/o connection to Mainboard.
                • nomoresonys
                  • 12206
                  • U.S.
                  Test drv_on pin at connector on powerboard, with everything hooked up, does the voltage change when you power up tv.
                  • Diah
                    • Feb 2013
                    • 6384
                    what does DRV_ON to do with BL ????????? this is new to me
                    sow us the print chart on the PSU of the socket which go to MB
                    • nomoresonys
                      • 12206
                      • U.S.
                      Nah, it's the same old shit, mainboard sends drv_on signal to powerboard, powerboard turns on backlights, no signal no backlight.
                      • Diah
                        • Feb 2013
                        • 6384
                        DRV_ON to switch 12V T-CON Matt
                        • Seb932
                          • Sep 2023
                          • 23
                          Sorry, this was a typo. DVR_ON is correct. Pin2 on P201 PSU side. Its normally feeded from INV_CTL (IC3000). Will enable Backlight.
                          If i bride SBY 3.5V on PSU with POWER_ON Pin1 P201 => all voltages are anabled on PSU. If 3.5V are supplied to DVR_ON on PSU side the backlight lights up.
                          • Diah
                            • Feb 2013
                            • 6384
                            in general TV PSU design.. how many STB (3.5V) pins you have at the sockets = how much signal the MB send to PSU during start .... i think here in this LG he had 3 pins STB means = 3 signal
                            • nomoresonys
                              • 12206
                              • U.S.
                              Do test in post #9, I think we want to see if the mainboard is sending drv_on signal, we know it works when jumped stand alone from your test.
                              • Diah
                                • Feb 2013
                                • 6384
                                then if you said so 12V & 24V you have and BL good,,, then why you work on PSU...
                                disconnect the panel from T-CON and try turn on normal.. BL should turn on and the Audio optic out put should lit red too if yours statement before correct
                                • Seb932
                                  • Sep 2023
                                  • 23
                                  No it does not come, checket on PSU side and on IC3000 as well. Pin stays Low...
                                  • Seb932
                                    • Sep 2023
                                    • 23
                                    Have tried it. T-Con disconnected from PSU & Mainboard but nothing changed => Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive. No Backlight and also no red light in optic port. Additional a quietly buzzing noise in the region of IC100 occurs...
                                    Put T-CON in again, buzzing sound is still there...
                                    • Diah
                                      • Feb 2013
                                      • 6384
                                      by the way,,, you can also move load on MB, by disconnecting speaker and wifi /BT module from it then turn on,,, this is weakness by LG
                                      • Seb932
                                        • Sep 2023
                                        • 23
                                        Maybe I've missunderstood. I've disconnected T-CON from the Mainboard. But reading carefully, you mean disconnect the panel from T-CON ...
                                        Tried again.... same result as before. Also in combination with disconnected speakers & wifi module...
                                          03-31-2024, 02:12 PM
                                          07-01-2024, 06:34 AM
                                        • brithepi2k
                                          Samsung UE75TU7020k No picture, Standby blinks 2 times
                                          by brithepi2k
                                          My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                          04-23-2025, 10:05 AM
                                        • cekanayake
                                          L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
                                          by cekanayake
                                          I am a noob with some elementary knowledge trying to fix this TV that I have no history on. Any help or guidance will be much appreciated.
                                          When I first examined it was completely dead. saw that the fuse was blown and the ICM801CS blown. I searched and found that the FSFR1800HSL might be the replacement and got one from ebay and replaced it. But when I pulled the ICM801CS I could see the last 3 letters on the blown up part was XSL. So may be I replaced it with the incorrect part. I fixed the fuse and turned it on and it now gives me a standby light blinking twice five times, then clicks...
                                          04-19-2023, 08:37 AM
                                        • htv239
                                          LG UH8500 Backlight Troubleshooting Help
                                          by htv239
                                          I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                          Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                          What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                          10-11-2021, 01:53 PM
