LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
  • nomoresonys
    • 12206
    • U.S.
    Re: LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
    Well then that looks like your problem, mainboard not sending drv_on signal, so no backlights.
    • Diah
      • Feb 2013
      • 6384
      put yours DM on T_CON Fuse 12V with Ref to TV chassis , then turn on did you have any reading?
      • nomoresonys
        • 12206
        • U.S.
        Anyone with a good memory remember? maybe it needs a good diy reflow of the bga.
        • nomoresonys
          • 12206
          • U.S.
          Do you have picture with the flashlight test?
          • Diah
            • Feb 2013
            • 6384
            friend,,, his psu error led lit red blinking.... mean there are issue on one rail,
            the rails are... 12v mb 24v mb 12v t-con and bl led
            • Diah
              • Feb 2013
              • 6384
              my last post over here.... as i wrote in my post #7 yours issue 99% BL.... forcing BL as stand alone never mean they are fine... you have edge LED BL, and each LED unit hat build in ziner Diode which can easily by time get open or shorted,,, yours TV from 2014.... LED life time almost 10,000 hours
              • nomoresonys
                • 12206
                • U.S.
                #27
                That was my first thought too Diah, It's 49 inches, I would have already had it tore down and be inspecting the leds quite closely.
                • Seb932
                  • Sep 2023
                  • 23
                  Update on next round: First I've disconnected the T-Con from MB. Then hooked up 12V to T-CON F1 and also forced DRV_ON and POWER_ON.
                  BL lights up and Panels cycles White/Red/Green...nothing, i would expect blue. Only a break (for blue) then starting from the beginning.
                  To rule out BL finally i also stripped the TV down afterwards, edgelight is working pretty well. No dark LEDs, burned spots or anything like that. Put everything together again...
                  My conclusion => T-CON has at least a problem (Blue color is missing)
                  • Diah
                    • Feb 2013
                    • 6384
                    pull out only the wire of DRV-ON from the PSU socket, and jumper the pins of the socket with 3.5V .. all other LVDS / ribbon cable should be in place... then turn on what you will have on the screen
                    • Seb932
                      • Sep 2023
                      • 23
                      Nothing because T-CON doesn't receive PANEL_VCC from MB. Thats why i've hooked up it directly to see if panel and T-CON are ok...
                      PANEL_VCC will be enabled by Q2303 with PANEL_CTL signal from IC3000, but signal is not coming (as well as DRV_ON from IC3000)...
                      I expect IC3000 is "waiting" for some other signals until releasing DRV_ON and PANEL_CTL....maybe related to the missing lower voltages on MB...
                      • Diah
                        • Feb 2013
                        • 6384
                        i see... t-con 12v come via lvds.. . then its MB... try warming it at the area close to LVDS socket... and check any change
                        • Seb932
                          • Sep 2023
                          • 23
                          Tried it, warmed up MB with a heatgun. Switched on, no change at all.
                          • Diah
                            • Feb 2013
                            • 6384
                            IC3000 on LG are MICOM, had his own script and controlled too with main firmware start script. you should have micro switch to reset it... it could help..
                            other wise repairing MB not easy task even for LG service center
                            follow the service manual ab page 31 and feed it with low V and to check low V are working fine
                            • Seb932
                              • Sep 2023
                              • 23
                              Have already tested the micro switch beside IC3000. It's the same like power on the TV. It triggers the MICOM reset => Power_On sequence starts again and stuck with the same result.
                              First question: You think about feeding additional external low voltage into the mainboard to bypass the voltage regulators?
                              Second question: what about the missing blue color in panel test mode? Could it be also a panel problem? How to test? If panel is dead I would not spend additional time...
                              • nomoresonys
                                • 12206
                                • U.S.
                                #35
                                Ok, I'm going back to my original diagnoses, reflow the bga.
                                • Diah
                                  • Feb 2013
                                  • 6384
                                  1- take out the MB and simulated the lowV start from STB 3.5 and down to all emmc V and so on
                                  2- the blue you have... other wise you will never see white RGB when all high level same value will present white color.
                                  • Seb932
                                    • Sep 2023
                                    • 23
                                    Damn, you are right
                                    lowV start signal is available on all the regulators, as well as VDD 12V. I've checked this already. Means input is ok for all voltages, but output not for low voltage.
                                    Looks like something grounds/overlay the output-signal...
                                    Output IC3000 => Voltage Regulation IC => Result
                                    POWER_ON/OFF1 => IC2304 5V => +5V_NORMAL OK
                                    POWER_ON/OFF2_1 => IC2301 3.3V => +3.3V_NORMAL OK
                                    POWER_ON/OFF2_2 => IC2302 2.5V => +2.5V_Normal OK
                                    POWER_ON/OFF2_3 => IC2303 1.5V => NOK PWM/rectangle signal with ~650kHz and 12V Peak
                                    POWER_ON/OFF2_3 => IC2300 1.0V => NOK PWM/rectangle signal with ~340kHz and 12V Peak
                                    POWER_ON/OFF2_4 => IC3409 1.2V => NOK PWM/rectangle signal with ~500kHz and 12V Peak
                                    Attached a picture from the scope with one of the regulator outpts...
                                    • Diah
                                      • Feb 2013
                                      • 6384
                                      Damn, you are right
                                      we do know the input are fine.. you did run PSU standalone...
                                      IC3000 from its behavior are fine for me.. we need to consider on emmc V and IC1000 V.
                                      you can start to capture the start log via JTAG..
                                      • Seb932
                                        • Sep 2023
                                        • 23
                                        Tried to find L2302 to check eMMC V. During search I found L2322 is burned (resistance 440Ohms), which is output for 1.2V
                                        Is it ok to bride the coil for testing purposes or better replace with some other SMD coil?
                                        • nomoresonys
                                          • 12206
                                          • U.S.
                                          #40
                                          Sure bridge for testing.
                                            03-31-2024, 02:12 PM
                                            07-01-2024, 06:34 AM
                                          • brithepi2k
                                            Samsung UE75TU7020k No picture, Standby blinks 2 times
                                            by brithepi2k
                                            My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
                                            04-23-2025, 10:05 AM
                                          • cekanayake
                                            L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
                                            by cekanayake
                                            I am a noob with some elementary knowledge trying to fix this TV that I have no history on. Any help or guidance will be much appreciated.
                                            When I first examined it was completely dead. saw that the fuse was blown and the ICM801CS blown. I searched and found that the FSFR1800HSL might be the replacement and got one from ebay and replaced it. But when I pulled the ICM801CS I could see the last 3 letters on the blown up part was XSL. So may be I replaced it with the incorrect part. I fixed the fuse and turned it on and it now gives me a standby light blinking twice five times, then clicks...
                                            04-19-2023, 08:37 AM
                                          • htv239
                                            LG UH8500 Backlight Troubleshooting Help
                                            by htv239
                                            I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
                                            Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
                                            What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
                                            10-11-2021, 01:53 PM
