LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
  • Diah
    replied
    Re: LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
    by the way,,, you can also move load on MB, by disconnecting speaker and wifi /BT module from it then turn on,,, this is weakness by LG
  • Seb932
    replied
    Originally posted by Diah
    then if you said so 12V & 24V you have and BL good,,, then why you work on PSU...
    disconnect the panel from T-CON and try turn on normal.. BL should turn on and the Audio optic out put should lit red too if yours statement before correct
    Have tried it. T-Con disconnected from PSU & Mainboard but nothing changed => Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive. No Backlight and also no red light in optic port. Additional a quietly buzzing noise in the region of IC100 occurs...
    Put T-CON in again, buzzing sound is still there...
  • Seb932
    replied
    Do test in post #9, I think we want to see if the mainboard is sending drv_on signal, we know it works when jumped stand alone from your test.
    No it does not come, checket on PSU side and on IC3000 as well. Pin stays Low...
  • Diah
    replied
    Originally posted by Seb932
    Sorry, this was a typo. DVR_ON is correct. Pin2 on P201 PSU side. Its normally feeded from INV_CTL (IC3000). Will enable Backlight.
    If i bride SBY 3.5V on PSU with POWER_ON Pin1 P201 => all voltages are anabled on PSU. If 3.5V are supplied to DVR_ON on PSU side the backlight lights up.
    replied
  • Diah
    replied
    Nah, it's the same old shit, mainboard sends drv_on signal to powerboard, powerboard turns on backlights, no signal no backlight.
    in general TV PSU design.. how many STB (3.5V) pins you have at the sockets = how much signal the MB send to PSU during start .... i think here in this LG he had 3 pins STB means = 3 signal
  • Seb932
    replied
    what does DRV_ON to do with BL ????????? this is new to me
    sow us the print chart on the PSU of the socket which go to MB
  • Diah
    replied
    DRV_ON to switch 12V T-CON Matt
    replied
  • Diah
    replied
    BL is fully functional. Tested by maual bridging SBY 3.5V to POWER_ON and DRV_ON on SMPS w/o connection to Mainboard.
    replied
    Test drv_on pin at connector on powerboard, with everything hooked up, does the voltage change when you power up tv.
  • Seb932
    replied
    you have much fault at LED BL
  • Diah
    replied
  • Seb932
    replied
    Have checked solderpoints, found some suspicious pins and resolderd it. Also have done some additional measurements.
    Started with IC3000, responsible for "power on" sequence
    If TV is switched on, the IC3000 enables the different voltage regulators. I've measured input signals (from IC3000) and output:
    POWER_ON/OFF1 => IC2304 5V => +5V_NORMAL OK
    POWER_ON/OFF2_1 => IC2301 3.3V => +3.3V_NORMAL OK
    POWER_ON/OFF2_2 => IC2302 2.5V => +2.5V_Normal OK
    POWER_ON/OFF2_3 => IC2303 1.5V => NOK PWM/rectangle signal with ~650kHz and 12V Peak
    POWER_ON/OFF2_3 => IC2300 1.0V => NOK PWM/rectangle signal with ~340kHz and 12V Peak
    POWER_ON/OFF2_4 => IC3409 1.2V => NOK PWM/rectangle signal with ~500kHz and 12V Peak
    Any further ideas?
  • Seb932
    replied
    Easy things first, check over the solder joints on powerboard, reflow any that look suspicious, check all the resistors and diodes on top of the board, youtube is your friend for how to videos if needed, examples of bad solder joints there: https://www.google.com/search?client...h=599&dpr=1.09
    Thanks for recommendation, will try to check and resolder suspicious joinst.
    replied
  • Seb932
    replied
    Good focused straight on pictures of each board and one of the whole back as to see how everything is connected.
    I've attached the requested pictures, hopefully sharpness & resolution is ok, otheriwse i need to use better camera.
    replied
  • LG 49UB850V not switching on / standby LED off / LD701 blinks 5x
    i'would like to fix my not working LG 49UB850V tv.
    Symptoms:
    -AC plugged in, Standby LED not working
    -Switching on, Standby LED blinks 3x. LD2300 on mainbord lights up and after ~30s LD701 on PWS board starts to blink 5x repetetive
    Checked already:
    -Powersupply Output in Standby => 3.5V ok
    -Switching On => PWR_On on P201 goes high and 3.5/12/24V are present on P201
    Any suggestions what to check next?
    Thanks in advance!
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • brithepi2k
    Samsung UE75TU7020k No picture, Standby blinks 2 times
    by brithepi2k
    My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
    04-23-2025, 10:05 AM
  • cekanayake
    L65X1Q_DHS / BN44-00627A Samsung UN65F6400AF Standby blinks twice five times
    by cekanayake
    I am a noob with some elementary knowledge trying to fix this TV that I have no history on. Any help or guidance will be much appreciated.
    When I first examined it was completely dead. saw that the fuse was blown and the ICM801CS blown. I searched and found that the FSFR1800HSL might be the replacement and got one from ebay and replaced it. But when I pulled the ICM801CS I could see the last 3 letters on the blown up part was XSL. So may be I replaced it with the incorrect part. I fixed the fuse and turned it on and it now gives me a standby light blinking twice five times, then clicks...
    04-19-2023, 08:37 AM
  • htv239
    LG UH8500 Backlight Troubleshooting Help
    by htv239
    I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
    Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
    What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors...
    10-11-2021, 01:53 PM
