Strong SRT5300 fails with no bulging electrolytics
  • japlytic
    • Oct 2005
    • 2086
    In a Strong SRT5300, I found that when the unit is turned on, all of the segments on the front display are stuck on.
    Measuring the power supply rails shown that the +3.3V rail was low, along with the +5V rail a bit too high .
    Replacing all of the electrolytic capacitors except the 400V unit fixed the problem and has shown that no damage was caused by a high +5V rail.
    The electrolytics on the power supply board were mainly Samyoung SHL and KME Series units, which were unsuitable for switching power supply service .
    • 31285
    Re: Strong SRT5300 fails with no bulging electrolytics
    that's standard crap, i used to fix hundreds of sat boxes.
    i never checked them first, just replaced all the caps and 99.9% of them started up and never failed again.
    the few times it still wasnt right, the ripple had corrupted the flash - a reflash of the firmware & they also never came back.
    • Nagy Daniel
      Lowest possible resistance on laptop motherboard rail - Guide Table request
      by Nagy Daniel
      Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
      I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
      I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
      So, I generated a table with AI so I can...
      03-04-2025, 08:24 AM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
    • lefetylorant
      Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
      by lefetylorant
      Hello Everyone,
      Long story short, I got this unit for very cheap.
      I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
      I've performed some measurements:
      - 20V rail perfectly...
      09-14-2023, 05:05 AM
    • bimole
      Weird behavior on 3.3V rail of a CORSAIR CX600
      by bimole
      A colleague gave me an apparently ill CORSAIR CX600.
      He told me that he heard a banging noise, and smelt the magic smoke.
      After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
      I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
      It's another story on the 3.3V rail...
      I have some devices to test deeply PSUs (scope, AC source, electronic load)...
      02-13-2025, 04:49 AM
    • mkdj
      Acer TravelMate P214 - N19Q7 main power rail shorted to ground
      by mkdj
      Dear all,
      I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
      I have checked resistance across each of the 4 MOSFETS. I have the following readings:
      Both N-Channel Mosfets: nothing odd
      P-Channel MOSFET number 1:
      source - drain : 117 kOhm
      source - gate: 96 Ohm
      gate - drain: 117 kOhm
      P-Channel MOSFET...
      08-20-2025, 06:08 AM
