42PFL3606H/58 no power
  • domix
    • Jan 2014
    • 166
    • Slovenia
    At this tv i have no power. I open it up. Fuse was blown and this on picture 2 is blown at one leg.
    What to? New chip and fuse or new board?
    What can i check.
    • 12206
    • U.S.
    Re: 42PFL3606H/58 no power
    Replace it, need to check all the components in that area, diodes, resistors and the 2 transistors there on their own little heatsinks, test those transistors for a short, none of the 3 legs should show continuity to either of the other two legs of the transistor.
    • lotas
      • Jan 2016
      • 4662
      • Russia
      As a rule, in these power supplies at 90%, if the standby PWM burns out, then it carries away the standby transformer (turn-to-turn circuit of the primary winding).
      • beetle1303
        Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
        by beetle1303
        I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
        On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
        01-13-2025, 08:49 PM
      • Babbar
        by Babbar
        04-12-2024, 01:12 AM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
