LG OLED 55EG9100 won’t power on
  • Diah
    • Feb 2013
    • 6439
    Re: LG OLED 55EG9100 won't power on
    here a Russian webos developer links for all Old LG firmware ... lotas may help with to look thru it too
    • Storyteller12
      • Jun 2020
      • 625
      I did the in-stop reset but after going through the setup process I'm still on 04.06.75.
      I'm not familiar with LG service menu etc. so maybe I did something wrong.
      • Storyteller12
        • Jun 2020
        • 625
        I noticed that if I play a video it plays almost perfect except for faint horizontal lines. But as soon as I pull up the menu I get this weird distortion on the bottom right. Could this be a possible tcon issue.
        https://youtu.be/G1VOOZkPehE
        https://youtu.be/T3OG6MJX970.
        • Diah
          • Feb 2013
          • 6439
          first of all downgrade .. after downgrade send IN_STOP again... and if it upgrade via Internet... let it and after it finish send IN_Stop again
          • Storyteller12
            • Jun 2020
            • 625
            Ok, I understand but I need firmware to downgrade. I went to the Korean lg site but can’t find my model or any referenced models. I couldn’t locate it on the Russian site you provided either. The closest I found was 55LF6300-NA but my reference list says I need 55LF6300-UA.
            I’m in the US and I believe that’s what the difference is
            • Diah
              • Feb 2013
              • 6439
              Man i gave you links at my post #21 thru the years LG TV production you will find many region firmware belong to yours TV serial to download
              in yours case year 2015
              to know which you need to download... go to setting and try to change countries.... any country listed at the TV you can download from the 4 option
              • Storyteller12
                • Jun 2020
                • 625
                Ok, my bad. Thanks for clarifying. I didn’t know I could download different country firmware. I didn’t see US listed so I didn’t want to mess anything up.
                • Storyteller12
                  • Jun 2020
                  • 625
                  I downloaded the old firmware and opened tv web browser and went to www.webosapp.club/downgrade/
                  But I get an error and ask if I have LG connect apps enabled.
                  I do have it enabled but still get the error
                  Other problem is tv started to randomly cut off and on after a few minutes. So I’m worried it will cut off during the downgrade process and brick it.
                    • 12276
                    • U.S.
                    #29
                    By randomly you mean it cuts off after a few minutes every time or sometimes it doesn't cut off, are you sure all your electrolytic caps are ok.
                    • Storyteller12
                      • Jun 2020
                      • 625
                      The time varies. Sometimes on for a 5-10min sometimes only 1-2 min.
                      I don’t think it the caps as I test power supply by itself prior to messing with the mainboard.
                      I thinks it’s related to the glitch on the screen I was having
                      • Diah
                        • Feb 2013
                        • 6439
                        send in_stop again
                        • Storyteller12
                          • Jun 2020
                          • 625
                          I did In-stop again and tv stayed on for a while. I downloaded the developer app and then it started to turn off and on again
                          • Diah
                            • Feb 2013
                            • 6439
                            then use other metode.. i prefer Apache server
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • mkdj
                              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                              by mkdj
                              Dear all,
                              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                              Both N-Channel Mosfets: nothing odd
                              P-Channel MOSFET number 1:
                              source - drain : 117 kOhm
                              source - gate: 96 Ohm
                              gate - drain: 117 kOhm
                              P-Channel MOSFET...
                              08-20-2025, 06:08 AM
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              09-06-2024, 05:59 AM
