LG OLED 55EG9100 won’t power on
  • Storyteller12
    • Jun 2020
    • 624
    I have this set and the standby light comes on but nothing happens when pushing the power button.
    Opened it up and did some testing and on the tcon I believe I found a short to ground. I circled the part. There is another one next to it that is not shorted to ground. So I was assuming this was my problem.
    Thanks for the help
  • lotas
    • Jan 2016
    • 4499
    • Russia
    Re: LG OLED 55EG9100 won't power on
    This choke (inductor) must be on gnd, since a negative voltage (-) VGL is formed on it.
    • Storyteller12
      • Jun 2020
      • 624
      Ok, thanks for clarifying. I've never troubleshot OLED before. Any idea where to start troubleshooting now?
      I've attached pics of the rest of the tv/ boards
      • lotas
        • Jan 2016
        • 4499
        • Russia
        In this model, micom (Renesas) is responsible for switching on; it contains its own firmware, check the power on it (3.3v), as well as the voltage on the dc / dc converters (chokes) and the resistance on them relative to the ground.
        • Storyteller12
          • Jun 2020
          • 624
          Attached is the readings. I get 0v going to the ic2300.
          Does that mean the ic labeled 100GEA is bad?
          • Diah
            • Feb 2013
            • 6353
            if the PWB turn off after SOS signal the micom will be stall to zero..
            put every things back as original only keep the socket between T-CON and PWB ( black one ) disconnected... turn on and check if you have the Audio opric on MB lit red.. and you have 12-24V on the MB socket or on the PWB side
            • Storyteller12
              • Jun 2020
              • 624
              I don't get any red light from optics and o 12v or 24v on pwb or main.
              Is this the cable you wanted to remove?
              • Diah
                • Feb 2013
                • 6353
                yes correct.... it mean you need to test the PWB as stand alone to be sure it work and start on to provide the requirment V to MB.... i wrote many time how to on OLED threats
                if you are not sure... u need to upload the photo of the socket between PWB and MB and the print chart on it... and test the PWB alone with out any socket connect to it just wall socket... see if the STB V 3.5 V or higher
                • Storyteller12
                  • Jun 2020
                  • 624
                  Ok thanks. I tested and only get 3.5 standby. I circled the The ones that get 3.5. The other one with a line shows nothing. No 12v or 24v. No power/ reading on any other pins.
                  I plugged everything back in and when I push the power button I do see the voltage on mainboard drop to 0 from 3.5v. So it is registering the power button being pushed.
                  • Diah
                    • Feb 2013
                    • 6353
                    PWB stand alone test only the PWB plugged in wall socket... jumpers
                    between STB 3.5V and Power On... .. this should turn on the PWB to provide 12V on socket pins
                    as first jumper in place make another jumper STB 3.5V to DRV_ON. this will generate 24V on the socket we talked before between PWB and T-CON
                    if this voltage you have at stand alone test.... mean yours issue at MB... if not then need to work on PWB.
                    Note... to avoid any mistake at assigned pins you are going to make jumpers... use MAx 1K Ohm in Jumper to avoid any damage if you missed with wrong pins.
                    • Storyteller12
                      • Jun 2020
                      • 624
                      Thanks for walking me through it.
                      I powered on and got all 12v and 24v rails. So on to the mainboard
                      • Diah
                        • Feb 2013
                        • 6353
                        good... so yours PWB OK... at MB there on OLED some ponits need to consider it.. the Last ate condition... mean if before the fault if the tv was on STB will go back to STB after power it on from local TV power on. or just plug it in wall socket... so need RC to power it on.... after that if you plug it out from wall socked and again in will start immediately (as the last state was On )
                        before you have only 3.5V STB. ( as you wrote ) so this point accurate
                        second... you have on the NB 2-3 micro switch to reset DC-DC- MICOM-and start script firmware... you need to try to press one by one and keep press for 10 second while you plug it in wall socket ( when the last state ON as i wrote before )
                        all above points should all cable ribbon LVDS connected as original... ONLY the the black wire socket between PWB & T-con disconnected.. and keep it disconnected until you see the OPTIC audio port lit red
                        • Storyteller12
                          • Jun 2020
                          • 624
                          I switched out the ic Lotas mentioned labeled 100GEA and TV now turns on and cycles red, blue, yellow, green but has horizontal lines across the screen.
                          The mainboard I took it from had this same symptom and we scrapped the tv because the screen was cracked anyway. So possible the IC I replaced with is bad.
                          I do have another to try but wanted to get opinions here before swapping it out again
                          Can
                          • Diah
                            • Feb 2013
                            • 6353
                            show me the line on screen at color pattern state
                            edit:
                            if cable coneccted and after power on patteren color show mean the MB provide 12 V T-CON. but no signal whixh lead T-con to start its own firmware.... you still have issue on MB.. or the t_CPN firmware didnt pass the first start script.... disconnecting the 24V and turn on the tv until you have Optic lit red keep it on for awhile then as its on.. plug back this socket
                            • Storyteller12
                              • Jun 2020
                              • 624
                              I switched the ic out again and the tv does turn on and show display, however the it’s still slightly messed up on 3 quarters of the screen
                              Obviously the red light on the optical port is working now
                              • Diah
                                • Feb 2013
                                • 6353
                                lotas wrote before micom had own script at firmware...now time to downgrade or update the firmware to let all parts will work together
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  Ok. Any particular one I should try first?
                                  Do I just update through internet or through usb with firmware?
                                  • Storyteller12
                                    • Jun 2020
                                    • 624
                                    Updating is a no go as the tv is already on the latest version 04.06.75.
                                    So I left with downgrading. Any good guide on how to do this?
                                    • Diah
                                      • Feb 2013
                                      • 6353
                                      there are several ways to downgrade .. from PC Apache server via LAN.( most recommend ).. or USB and via the browser of the TV... .. you may try too to send IN_STOP via Service RC. the last firmware TEMP saved on TV and it will roll back with this command .... hope will solve the issue... if not then downgrade
                                      • Storyteller12
                                        • Jun 2020
                                        • 624
                                        I will try in stop and hope that there is a TEMP saved firmware. If not I have read up on downgrading. However the problem I have is I cannot find an older firmware for this model. I tried the Korean LG site and also looked on the Russian site. But didn’t see anything for 55eg9100 or any of the reference models for this TVs firmware
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          03-31-2024, 02:12 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
