Visio V755-G4 LED TV: No backlight, have sound, see menu with light.
  • Grasshopper2Ant
    • Jul 2023
    • 15
    No backlight issue. Have sound and can see menu with flashlight.
    Suspect LED driver, voltages are 100V each side. What should the voltages be for 75 inch TV on the Power Supply Board? I have 96 leds x3 volts per=288/2=144 volt per side?
    Am I low on my volts causing the leds not to light up?
    Before I got all backlights out, the right side was a bit darker than left side. How many leds
    need to be out for all to not work?
    Thinking of getting a led tester. If leds light up, would that confirm it is the Power Supply Board?
    I do not want to dismantle entire board to get at leds at this time and hope to diagnose it is not.the PSB
    Thanks for any help guys!.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Visio V755-G4 LED TV: No backlight, have sound, see menu with light.
    It's LEDs not driver.
    • Grasshopper2Ant
      • Jul 2023
      • 15
      Thanks for reply. Anyway to confirm this 100%.
      • Grasshopper2Ant
        • Jul 2023
        • 15
        Here is similar board as mine. Can someone tell me how many volts I should be getting at the two LED driver connects on 75 inch Vizio?
        Also, I am getting a 300V led tester. If the leds light up on both connects, would that confirm it is power supply board?
        Thanks for any help!
        • Grasshopper2Ant
          • Jul 2023
          • 15
          Power Supply board at LED driver connectors on and off board with power plugged in.
          180 plus volts at connectors and board at start-up and dwindles to 100 volts in 5 seconds.
          No Vizio logo or backlights.
          Is this a normal board booting up?
          I am resided to it being backlights but still want to do the 300V LED tester test.
          • Grasshopper2Ant
            • Jul 2023
            • 15
            Dismantled the TV.
            Tested the LEDs with tester. 2 rows consisting of 6 leds each side are out. That is 24 leds out.
            Trying to take the reflector sheet off but it is glued to the leds.
            How does one deal with the reflector sheet without tearing it. Very poor design by Vizio.
            Anyone else have this problem and how did you solve it?
              • 12241
              • U.S.
              That sounds pretty odd, post a good picture of this.
              • Grasshopper2Ant
                • Jul 2023
                • 15
                The led strips are glued to the back as well as the reflector.
                I decided to cut the reflector around the leds. Lots of extra bullshit but once I carved out the first one I used it as a template for the rest. Tedious but just get a rhythm going.
                A strip with 6 leds measure 34V on my tester.
                Ordering a set and update later.
                • bscottjohnston
                  • Aug 2023
                  • 52
                  Dismantled the TV.
                  Wondering if a heat gun on low or a hair dryer might get the sheet out without damage. On my 70" Vizio with the panel out the LEDs would start up and I could see which ones were damaged without the tester.
                    • 12241
                    • U.S.
                    Could use a hairdryer, not too hot of a setting but most will peel right off with steady slow pulling, did a big vizio the other day, each led had it's own little screw beside it holding the sheet in place, have not seen that very often.
                    • Grasshopper2Ant
                      • Jul 2023
                      • 15
                      Thanks for tips guys!I
                      I looked at a shop Jimmy video and he cut it out with Olfa razor blade.
                      That is what I did. 16 strips. Top 4 rows had screws on LED strips, bottom 4 was glued with white thermal tape.
                      To put back new strips I used double sided thermal tape and on reflector edges and installed.
                      As a tip, buy or source the tape beforehand. I could not find it anywhere at any
                      Ordered on Amazon. Cheaper if you have time to get from Aliexpress.
                      Anyways, all was good till I messed up install which I will start a new thread for help.
                      • Grasshopper2Ant
                        • Jul 2023
                        • 15
                        The LEDs I had on my strips were all out on the bad rows, 4 rows.
                        I replace bad ones with existing good ones and all light up. I did same to other side and all lit up.
                        I tested a strip and I could not get one individually to light up with my new led tester.
                        Probably testing it wrong.
                          LCD LED TV Service Menu Codes
                          ALL LCD LED TV SERVICE MENU CODES
                          Service Menu Code with Board Name
                          China Universal Board / Jumper Board Service Menu Code
                          Changhong Ruba Service Menu Code
                          Ecostar LED TV Service Menu Code
                          Orient LED TV Service Menu Code
                          Haier LED TV Service Menu Code
                          TCL LED TV Service Menu Code
                          Samsung LED TV Service Menu Code
                          LG LED TV Service Menu Code
                          Videocon LED TV Service Menu Code
                          Supra LED TV Service Menu Code
                          Toshiba LED TV Service Menu Code
                          Symphony LED TV Service Menu Code
                          Veste/ LED TV Service Menu Code...
                          10-31-2024, 03:58 AM
                        • MOSSEP
                          Monitor Audio RSW12 - Green light, but no sound
                          by MOSSEP
                          Hi
                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                          I have already tried replacing all of the...
                          01-26-2025, 08:33 AM
                        • ChaosLegionnaire
                          by ChaosLegionnaire
                          09-13-2022, 09:02 AM
                        • kca
                          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                          by kca
                          Hello all ~
                          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                          No picture. No sound.
                          I tested all the voltages coming out of the power supply...
                          10-12-2023, 05:23 PM
                        • edugimeno
                          Help me identify the missing component... Sound to light circuit
                          by edugimeno
                          hI there!
                          Im trying to help a friend repairing a large, real-sized short-circuit robot.
                          This is remotely controlled and has a 2 way voice send/receive. Also while the hidden operator is talking, the red bulb inside the "mouth" should flash according to the sound
                          Some other technician used to service it and he was fired leaving all the repairs unfinished and no documentation at all.
                          What I found is a sound receiver, a speaker, and a wire directly to the mought bulb (a normal motorbike 5W 12V bulb).
                          So I bought a simple 2X30W amplifier to feed the loudspeaker...
                          02-14-2024, 10:23 AM
