Vizio P552ui-B2 Backlight Diodes
  • per4manz
    • Jan 2015
    • 5
    • US
    Have a Vizio P552ui-B2 that is starting loose backlight diodes. While I know I can get a hold of used strips, I would rather replace the diodes directly instead of used strips that will likely also start to fall quickly requiring me to tear the TV apart repeatedly to repair it.
    With that being said, does anyone know what voltage and diode package are on the strip for said TV? The strip model number is WT-EL-55UHD-A-V3. Again, I also don't want tear the TV apart in and attempt to see if I can find out this info.
    Any help would be greatly appreciated.
  • petehall347
    • Jan 2015
    • 4436
    Re: Vizio P552ui-B2 Backlight Diodes
    buy new ones and reduce brightness if you dont like taking it apart .
    • per4manz
      • Jan 2015
      • 5
      • US
      I am not sure I follow. Do you mean buy new strips or diodes?
      Wish I could find new strips as I would get them, but this TV was purchased in 2014/15 and I can't find new parts for it anymore. That's why I was asking about the diode voltage and package type so I can just order enough to replace every single diode while I have it open.
      I don't mind taking it apart but also don't want to repeatedly if I can avoid it.
      • Storyteller12
        • Jun 2020
        • 625
        Tvpartsguy.com shows 1 set in stock. Never dealt with them before though
        • diif
          • Feb 2014
          • 6978
          • England
          There's a lot of LEDs to swap. https://www.ebay.co.uk/itm/223924920427
          • petehall347
            • Jan 2015
            • 4436
            128
            • per4manz
              • Jan 2015
              • 5
              • US
              I appreciate that. It's strange that this seller is in the US, yet the item for sale is listed only on the UK Ebay site.
              • per4manz
                • Jan 2015
                • 5
                • US
                Thank you. I have come across that in my searches. However, "Please Read Before Purchasing:TvPartsGuy.com is a Tech to Tech sales company. We strive to help the Tech community find hard to get TV Parts at an affordable price. Registered Techs and Service Centers receive a 90 Day Warranty on all orders & No Restock Fee on Store Credit Returns."
                Thus, I could get a set and have one of the LEDs burn out quickly and be back in the same boat I am in. That is why I am trying to find the specs on the individual LEDs (package, voltage, color temp). If I can get those without opening the TV I can order enough to replace every single one after I open it up. ShopJimmy has some good videos about this and I have the equipment to do it.
                • Storyteller12
                  • Jun 2020
                  • 625
                  I wouldn’t waste so much time worrying about leds burning out again. Usually the processor on the main board fail on this TV. Most likely that will go bad before leds so again
                  • nomoresonys
                    • 12266
                    • U.S.
                    The leds can burn out one right after the other, which makes sense since they are all the same age, do you really want to be tearing it down every week, I would get a whole set, from a trusted seller on ebay or aliexpress, replace and turn the backlights down as far as tolerable AND get yourself a fan blowing on that processor, it should last a lot longer than without one.
                    • Dvsr
                      On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                      by Dvsr
                      Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                      I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                      After replacing the caps I started testing out the speaker. It seemed...
                      09-10-2025, 10:20 AM
                    • howardc64
                      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                      by howardc64
                      Failure Symptom
                      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                      Where is the short?
                      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                      05-27-2025, 02:56 PM
                    • caspian
                      What Zener Diodes on a Linear Power Supply
                      by caspian
                      Dear members,
                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                      In addition, I discovered that its zener diodes are defective.
                      I can replace the burned transistors.
                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                      Therefore, I cannot replace the zener diodes.
                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                      no schematics are available...
                      05-26-2025, 12:38 PM
                    • Kingfreddie
                      LED problem on samsung UE55F6475, 2 strips work. The rest is flashing every second.
                      by Kingfreddie
                      Ok.. this is the story:
                      Have an old Samsung LED 3D TV (UE55F6475). First it started to lose light on the lower 40% of the screen now and then. Like for 10-60 mins and then it would work again. Then a bit later it just got stuck in that position. The lower 40% of the screen is dark, and it gets progressively darker the lower u go so it's obviously that LED strips where not working. I also looked for similar errors online and saw an exact copy and on that one it was faulty LED strips.
                      This is kinda how it looked, just that mine were at the bottom of the screen:
                      09-11-2021, 01:57 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
