TV standby to power_on circuitry theory and operation
+ More Options
Posts
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Although it is far from my main field of interest, people here keep asking me to fix their flat screen TV's.
    So far, the problems have generally been on the PSU, the T-Con or the backlights, all of which have been relatively straightforward.
    As far as the main board, or SSB, is concerned, the only real issues I've encountered have been bad caps and fucked BGA soldering.
    It has also become clear that 'stuck in standby' is a common problem, and something which I no experience with yet could waste lots of time on without an understanding of how the 3v3 is sent to trigger the relay which brings the whole unit to life.
    Which leads me to my question, "does anyone know of a good resource which covers the theory and operation of the Standby to P_on circuitry?"
    Many thanks in advance
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: TV standby to power_on circuitry
    With no information on model, or board design, there's no universal "follow this" guide when it comes to standby>power on operation, could be anything.
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      That's fair enough.
      I'd assumed that there would be some generic form of setup, in a similar way that the ATX power supplies all ground the green standby wire in order to switch the unit on.
      From the limited experience with TV's that I have, it certainly seems that most TV's use a similar 3v3 system to activate the relay which powers the backlight and the MCU circuitry.
      I suppose I was half-wondering if TV's also grounded the standby voltage?
      If you are saying however, that there are many different ways to power-on out of standby, then I clearly have lots of reading up to do.
      • CapLeaker
        Leaking Member
        • 8173
        Re: TV standby to power_on circuitry theory and operation
        Nope, not always the case. I guess you can determine if the PSon has power vs not having power. STBY voltage is generated on the PSU and sent to the main board main IC. That’s why a little LED is on on some TV’s. It also power the IR sensor. Once you press the power button, the main board sends PSon and BLon and maybe some DIM signals to the PSU, the PSU turns fully on and the mainboards boots up.
        Some PSU’s have a pull up resistor, so the power supply turns on automatically if you disconnect the main board. You can force a PSU a on, by taking a 1k resistor and jumping STBY to PSon, BLon, DIM etc. In these you don’t ground out the PSon pin, you put STBY voltage to it.
        It’s a short and crude version and basically all condensed in a nutshell.
        • Biruslapio
          • Nov 2013
          • 552
          • Brasil
          I figured they wanted to know another thing, why do TVs gets stuck in stand-by, not how to force psu on, because there's obviously a way to do that, but that too depends on the TV model and can be done without main board, your listed method should work almost always.
          The usual reasons a TV can't wake up from STBY if it receives a power-on command via either the button or infra-red AND sends no power_on signal to the PSU, is usually > bad firmware or damaged main chip on the main board, with recent cheap TVs having crap and unreliable firmware they get corrupted from time to time, if it's stored in a non-BGA chip it is easy to re-flash.
          • Rajnhl
            • Oct 2018
            • 94
            • India
            sometime voltage regulators, specially passive ones fail. you need good meter to find problem. I have done many local brands in which 3.3v regulator was giving 3.25 to 3.27v volts and board stuck in standby mode.
            we are never expert, we master one thing, new technology arrives.
            • Crystaleyes
              • Sep 2021
              • 493
              • Brazil
              Hi Rajnhl.
              Are you saying that 3.27v is not enough?
              • Rajnhl
                • Oct 2018
                • 94
                • India
                Originally posted by Crystaleyes
                Hi Rajnhl.
                yes . i checked in many local brands
                • Crystaleyes
                  • Sep 2021
                  • 493
                  • Brazil
                  Thanks.
                  Good to know for the future...
                  • redbaron1007
                    Yamaha HTR-3065 No power/No Standby
                    by redbaron1007
                    I got a Yamaha HTR-3065 on the bench currently that's got a no power/ no standby issue.When I plug it in it draws 0.01A from the wall, the relay for the ac transformer never clicks, there are no standby lights on the front, and pressing the power button does nothing. The fuse was not blown but upon measuring the voltages on the power low voltage power supply board (labeled operation 3 pg 89 in the schematic) they do not match what the schematic says they should be.
                    S9 13.7V
                    Pwr Ry 0V
                    AC Det 9.1V
                    Mgnd 0V GND
                    The two pins on the transformer for the operation...
                    09-12-2024, 03:04 PM
                  • Crystaleyes
                    Samsung BN44-00259A standby question
                    by Crystaleyes
                    Hi all.
                    I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                    SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                    Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                    The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                    08-11-2023, 05:15 AM
                  • fharris1977
                    Vizio D50u-D1 Dead Set No Standby
                    by fharris1977
                    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                    12-28-2023, 10:25 AM
                  • psssst
                    Yamaha TSX 120 Standby Problem
                    by psssst
                    Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                    03-01-2024, 07:25 AM
                  • reessi
                    JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                    by reessi
                    I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                    You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                    Years ago it had some bulging caps...
                    04-26-2021, 11:42 AM
