LG OLED55B6V dead ! Please help.
  • markolino
    • Mar 2020
    • 109
    • Slovenia
    welcome. I have owned an OLED TV for several years, the LG model OLED55B6V
    a few days ago that I would turn on the TV like every day.... puffff, the TV is dead. I press the button on the remote... a relay clicks and the light blinks red 3 times then stops. it is necessary to turn it off and on again to repeat the process
    i tried the method of holding the physical a button note while plugging in the main power cord and no luck.. in short, any idea what could be wrong??
    al main board al power board ??
    your opinion?
    you can also watch my video below
    https://youtu.be/SHWWFqM7seE
  • markolino
    • Mar 2020
    • 109
    • Slovenia
    Re: LG OLED55B6V dead ! Please help.
    MR @Dish, are you familiar with this error?
    • EazyBone
      • Jun 2023
      • 1362
      • United states
      Probably electrical failure. Capacitor failure in power board or power board itself could be likely.
      • markolino
        • Mar 2020
        • 109
        • Slovenia
        aaaah. which capacitors have high voltage (primary) or low voltage (secondary) at a glance, they are all ok.
        the big ones that are put together at the primary voltage show me 250Uf, all three together. i.e. 80uf x 3, it says that they are from 100Uf.
        but I found 1 yellow capacitor first from the right and it is short circuited.. maybe but that's how it has to be?? the rest are not..
        I will mark it in the picture.
        Model of Power Board is: lgp55b-16op
        • R_J
          • 9623
          The point you circled on the trace side of the board is NOT the capacitor, they are the same points of the trace.
          Check the power supply voltages, they are marked on the board.
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            Found this while searching for my problem. Use English captions
            https://youtu.be/pSRxAuLAwSU
            • markolino
              • Mar 2020
              • 109
              • Slovenia
              yes, in this video, we change the main board, but the error indicates the power supply.. in this video, there is no reason at all how he found the error, he just replaces it.. anyone can be such a repairman
              my situation is a little different. in his video the red light comes on immediately when he turns on the AC
              in my case, when I plug it into the mains, the sound of the relay is heard. and the red light flashes quickly.
              I'll wait a few seconds. and when I want to turn on the TV with the remote or the button, the click is heard again and after 2 seconds the sequence of flashing 3x red light starts
              • Diah
                • Feb 2013
                • 6550
                there are no blink code count on LG OLED. the 3 blink are normal at any start, its described each blink as running one start script. so this bring nothings to you keep watching the blink.
                OLED trouble shooting we do wrote several time at any of OLED threat. read them all ...you need
                1- test PSU as stand alone ( to be sure the PSU produce all required currents to MB or T-CON driver boards
                2- running the T-CON driver boards as stand alone with help point one. ( to know if the Panel module have short cells or not or burn )
                so read please all threat . and there the answers you will find.
                my answer guilt for @EazyBone threat too
                • markolino
                  • Mar 2020
                  • 109
                  • Slovenia
                  ah, so with OLEDs, they don't have a way to look at the error lights..
                  • EazyBone
                    • Jun 2023
                    • 1362
                    • United states
                    This is why I am here for direction. If I knew where to look I wouldn't be asking, I've went through many threads but it's hard to read all these things I don't fully get. If it's already answered then I'd someone can just link the thread and is gladly look at it to get my answer. I don't know how to test pay, and I don't know how to test tcon standalone. Trying the best I can, if there is the thread for this can you link it? Thanks
                    • markolino
                      • Mar 2020
                      • 109
                      • Slovenia
                      I made measurements when everything was connected normally, I had accurate measurements on all pins, except for 24V, there was none.
                      when I turned on the TV, it showed 7V on the pins where it goes to the T-Con
                      and on the return from the MB on the DRV-ON pin it was 0V
                      PWR-ON has 3.7V
                      then I made a jumper between PWR-ON and DRV-ON so as to force the power board to trigger 24V
                      and here I really turn on the TV, the relay click shows 24V on all the pins that go to the T-Con board, but there is no picture. The theme is perfect..
                      so I conclude that the Power Board is working...
                      but I don't know how to force the power board itself without MB to start all the necessary voltages? because with PWR-ON I need 3.7v and DRV-ON equally..
                      any advice?
                      below are some pictures..
                      I also tried disconnecting the LDSV cables from the MB to the T-Con.. the thing is the same, there is no picture.
                      I tried to disconnect all 4 flat cables leading to the panel.
                      In short, I assume that here the MB board is not working as it should... because it does not trigger DRV-On
                      • lotas
                        • Jan 2016
                        • 4841
                        • Russia
                        This is LG. The motherboard has locked up due to panel errors.
                        • markolino
                          • Mar 2020
                          • 109
                          • Slovenia
                          how could I try to reset it in some way??
                          • markolino
                            • Mar 2020
                            • 109
                            • Slovenia
                            so I have nothing to do without a service remote control?
                            • markolino
                              • Mar 2020
                              • 109
                              • Slovenia
                              the thing is like this. Here I bought a service remote for an LG TV
                              where on the forum can I get info on how to use it?? where do I know how to factory reset the motherboard? I'm looking but I can't find it
                              please someone help me.
                              remote control image.
                              • markolino
                                • Mar 2020
                                • 109
                                • Slovenia
                                Hi guys.. Hwer is the button for reset???
                                • Asraf Atb
                                  by Asraf Atb
                                  01-27-2025, 05:02 PM
                                • Dani_2024
                                  by Dani_2024
                                  10-28-2024, 05:06 PM
                                • ygorsan
                                  by ygorsan
                                  🧩 Problem Summary:
                                  • I
                                  07-28-2025, 08:34 AM
                                • jb_Bak
                                  by jb_Bak
                                  CN6401
                                  Pin 01 NC
                                  Pin 02 NC
                                  Pin 03 "BL_ON": 0V
                                  Pin 04 "N/C"
                                  Pin 05 "STBY 3.3V": 3.5V
                                  Pin 06 "GND": N/C
                                  Pin 07 "AC_OFF"...
                                  09-27-2021, 04:52 PM
                                • JDC
                                  (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
                                  by JDC
                                  ONN 100012588
                                  Issue: No Power, Then Rebooting After Main Board Change
                                  Short answer: replace main board and power board
                                  Technical answer: replace main board and Q306 & Q307 on power board.
                                  Long answer:
                                  TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
                                  07-15-2022, 07:39 AM
