JVC LT-40C550 PSU Backlight Fault
  • jdawg99
    • Sep 2022
    • 11
    Hi Guys,
    Wonder if I can get some advice on this please. The fault is a noticeable darker screen on one half of the TV. I have checked both arrays and they seem fine. I have swapped the led outputs on the PSU and proven it's not the LED's. There is a bad output voltage on one of the ports but seems almost like some kind of grounding issue or something. From TV chassis I get 60+ Volts on the positive of each string but if I measure across the bad one (tested on both arrays) I only get 2 ish volts. If I measure from TV chassis ground to the negative I get 32v. I have done a little video to show what I mean
    https://www.dropbox.com/s/gz4yisxm48...10011.mp4?dl=0
    The PSU is a TV3902-ZC02-01(F)) and the IC I am measuring on is a ob3368ap.
    Thanks in advance
  • howardc64
    Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
    by howardc64
    • Prior owner tried a replacement main board. No difference.
    • Samsung 2x red blinking standby LED = panel fault
    • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
    • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
    • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
    07-19-2025, 10:54 PM
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • Superbee_dad
    Sharp 80” long short flash backlight error - Help
    by Superbee_dad
    Hello Sharp TV experts
    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
    01-24-2025, 11:51 PM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • u666sa
    HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
    by u666sa
    Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
    Platform: ipa32 la-m024p rev 1b
    Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
    I found a short on the other side:
    10-04-2025, 05:03 PM
