Samsung 65NU6070 strange panel issue???
  • Storyteller12
    • Jun 2020
    • 624
    I have this TV and at first no picture/ display.
    I traced it down to the panel I believe. If I cover a few pins on the lvds cable the display works and has a perfect picture.
    However after watching it for a week it reverts back to same problem. When I turn it on it's a blank screen again.
    I can verify the power board has all the correct voltages and I can still hear the tv and it powers on and off like it's supposed to. So assuming mainboard is good.
    Now after sitting for 2 weeks I turn it on and perfect picture again.
    Not sure what else it could be. Any insight would be helpful.
    Note I'm only covering 3 pins on the lvds cable there inside the black lines I made
  • Diah
    • Feb 2013
    • 6357
    Re: Samsung 65NU6070 strange panel issue???
    i don't know which pins you masked..
    but in general. Panel cells need an discharge action.. if you by chance blocked this action trace.. the panel after while of use will be blind /Jam
    • Storyteller12
      • Jun 2020
      • 624
      Ok thanks for the explanation. I’ll count the pins masked and see if I can find out what they’re for.
      Someone, I think Lotas had a pin out of the lvds cable for another tv I was working on. Maybe he could chime in with the info for this model as well to identify the pins.
      • howardc64
        • Jun 2017
        • 598
        Originally posted by Storyteller12
        Ok thanks for the explanation. I'll count the pins masked and see if I can find out what they're for.
        Here is your service manual. pg 5-5 5-6 are the t-con to panel signals.
        https://www.electronica-pt.com/esque...s-uez83-68457/
        • Storyteller12
          • Jun 2020
          • 624
          Thanks Howard, I appreciate it.
          • howardc64
            • Jun 2017
            • 598
            I did a write up on this era Samsung panel signal pins that might help after you figure out what pins are masked.
            https://www.badcaps.net/forum/showpo...44&postcount=5
            • Storyteller12
              • Jun 2020
              • 624
              Thanks for the link and info. I will definitely look it over to learn more about panels and panel defects.
              So I have pins 21-24 covered.
              Pin 21 is fsc1, pin 22 is ground, pin 23 tx_ch8_a+_usit, and pin 24 tx_ch8_a-_usit
              • howardc64
                • Jun 2017
                • 598
                Can you take a pic like this?
                https://www.badcaps.net/forum/attach...1&d=1681884737
                Its really easy to get the pins reversed between service manual and actual cable.
                The pair of USIT lines transmit pixels for a section of vertical column. If these are used by t-con (not all USIT are used, read on) and blocked, you will see a picture like this
                https://www.badcaps.net/forum/attach...0&d=1681883964
                Samsung often don't use all the USIT pairs lines on the cable. Since you don't have any picture problems, this USIT pair maybe unused OR got the pins backwards. Thats why I asked for the first picture. If you look at my first board picture carefully, you can see many trace pairs running to the flex connector. Each pair is a USIT pair responsible for a column section of the screen. flex and connector specification usually have more USIT connections than the board actually connects so some pairs are not used.
                There are many GND lines on the flex so blocking one should be okay (I guess?) Don't know what FSC1 is. In any case, lets start by making absolutely sure we have determined the correct pins that are blocked.
                • Storyteller12
                  • Jun 2020
                  • 624
                  Hope this helps. I don't use paper to mask off and it was a little difficult with it leaning against the wall. Laying it flat down would have been much easier but no space at the moment.
                  • howardc64
                    • Jun 2017
                    • 598
                    Hope this helps. I don’t use paper to mask off and it was a little difficult with it leaning against the wall. Laying it flat down would have been much easier but no space at the moment.
                    Your main board's (BN94-14047J) t-con trace doesn't match the UN65NU6900F service manual I provided despite being very similar.
                    TVPartsToday's main board compatibility shows your board PN (BN94-14047J) matches UN65NU6900FXZC. But this board pic also doesn't match t-con trace of the UN65NU6900F service manual. Perhaps there are panel factory and t-con differences for FXZA FXZC etc... Don't know.
                    https://www.tvpartstoday.com/BN94-12...n94-12873j.htm
                    So while you blocked out pin 21-24 on CN1301, we don't know what signals you they are. But there are some clues
                    CN1301 shows pin 22-26 are all ganged together. This is likely a power rail (see the big SMD caps nearby. Likely board GND on the other side of these caps) But you didn't block 25-26 so the power rail is unblocked. Maybe it is unnecessary to block 22-24 as well?
                    Maybe pin 21 is the only pin that requires masking? To find out what this pin is, use multimeter diode/continuity mode to find see the equivalent pin/trace on the 1) other T-con connector (CN1300) or 2) the buffer boards and hope there is a label
                    Here are many Samsung service manuals. I searched but unfortunately couldn't find a main board t-con trace pattern that matched yours.
                    https://www.electronica-pt.com/esque...erby,4/page,1/
                    • Diah
                      • Feb 2013
                      • 6357
                      with out the mask. which issue you will face..
                      from location of the pins regards yours photos it went to the left side ( when you look from the back side ) and you have the U ribbon on the buffer boards. i would try to remove the mask and disconnect the U ribbon then let see which kind of issue you are facing.
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Ok, today I come in turn the tv on and here is what I get.
                        • Storyteller12
                          • Jun 2020
                          • 624
                          Diah: I did try to remove tape and unplug the u ribbon on the buffer boards but got no image still.
                          • Storyteller12
                            • Jun 2020
                            • 624
                            Just now I turn tv off and back on and perfect picture again. I'm at a loss
                            • Diah
                              • Feb 2013
                              • 6357
                              so the main issue was black screen
                              and with this post of you there are no any masking or U ribbon disconnected
                              • Storyteller12
                                • Jun 2020
                                • 624
                                Yes blank screen.
                                And I had to cover pins 22-24 to get a picture
                                • howardc64
                                  • Jun 2017
                                  • 598
                                  Yes blank screen.
                                  Since pin 22-26 are all ganged together on main board side, maybe pin 25-26 isn't connected on buffer board side and only pin 22-24. Anyway, require continuity checks to confirm.
                                  Maybe worth checking voltage on pin 22-24 for hint what is masked off.
                                  • Diah
                                    • Feb 2013
                                    • 6357
                                    i don't think so.... yes it some things to not connected... but its much sandwich boards... i would put the MB on the BGA plate and heat it from downside for long period of time. of course with the max Temp..
                                    BTW thought he got full screen with out any mask or diy... so its much BGA rather than shit SAMI Panel we do know
                                    or you may right too in condition the sockets on MB or Panel buffer boards.. the level on´f the pins contact aren't at same high... so the clip will miss 1-2 left right of the high position of the pins.
                                    • NWArkGuy
                                      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                      by NWArkGuy
                                      Well, I will be the first to admit that I screwed up...
                                      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                      I have 2 that I have found and have in my possession. ...
                                      10-12-2023, 10:13 PM
                                    • howardc64
                                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                      by howardc64
                                      • Prior owner tried a replacement main board. No difference.
                                      • Samsung 2x red blinking standby LED = panel fault
                                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                      Yesterday, 10:54 PM
                                    • stylishconsultant
                                      un60j620dafxza - Samsung No Display Problem
                                      by stylishconsultant
                                      Hi All,
                                      Need help.
                                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                      09-04-2024, 03:26 AM
                                      09-07-2024, 05:50 AM
                                    • triplefour
                                      LG 75UN8570AUD panel issue fixed with tape.
                                      by triplefour
                                      I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                                      add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                                      07-17-2023, 10:22 PM
