Re: Sony XBR-65X750D Horizontal lines bottom of screen
I assume power was off when you were doing masking or any unplugging of cables on the TV? If not, certainly risks. Also ribbon ables insertion can be tricky to seat properly without magnifying eye wear. There are notches on both side of the ribbon that needs to be seated properly. But not fully seating probably shouldn't cause shorts.
Do resistance checks on both side of the CLK1-8 resistors on the non burnt side and cross check against the burnt side. This may provide some hints.
Hi Howardc64, The Resistors on the Left side appear to be OK (see pictures). I just purchased from eBay some 0805 100ohm resistors and a digital soldering iron with adjustable heat settings in hopes that it might enable me to reinsert the burnt resistors. Thinking back, when I was masking off the ribbon cable from the T-Con board I smelled burnt components 1 or 2 times. I am wondering if I was the source of the burnt resistors because even though I tried to be careful, I may have not reinserted the ribbon cable correctly. Anyway, I am just second guessing myself right now. Thanks again for your help. The “new” resistors and soldering iron should arrive the middle of next week. RegardsLeave a comment:
Can you post a pic of the CLK1-CLK8 on the other side of the panel? I wonder if there is failure there and now depends on the side with burn marks.Leave a comment:
I can take a look for you with better soldering tools if you want to bring it by Redmond/Sammamish area.Hello Howardc64, Yes, it is strange to me too. Shouldn't it have responded like you suggest when I masked off the contacts from the T-con board? I am beginning to think this TV is a lost cause beyond my capabilities. I got my 100ohm 1/4 watt resistors today and they are giants compared to the resistors I am trying to replace (see picture) The two "dots" between the resistors and the penny are the resistors of equal size to those that burned out. See picture. Regards, GilLeave a comment:
These are all gate driver signals. Its been kind of a mystery to me what removing 1 or more should do. My understanding is should have no effect as the duplicated gate drivers lines on the other side of the panel will just take over.Hi, While I am waiting for the 110ohm ¼ watt resistors to show up in the mail, I decided to “tin” the resister contact points with the most pointed soldering iron I have. In the process, I de-soldered the resister next to it but it did appear to have one end broken already. Anyway, I am posting the picture as it shows on the TV now in hopes that it might give a clue to a possible cause of the problem(s). Originally, I was experiencing horizontal lines only 6 inches up from the bottom, now I have horizontal lines over the entire display. Please see attached pictures of the TV (upside down). The first picture shows where the horizontal lines used to stop. Thank you again for the help.
But this is all before whatever damage to the logic caused by the fault.
So best path would be to remove all to see how it looks and put back one by one. But since you don't have the necessary equipment, seems not a possible path.Leave a comment:
Hi, While I am waiting for the 110ohm ¼ watt resistors to show up in the mail, I decided to “tin” the resister contact points with the most pointed soldering iron I have. In the process, I de-soldered the resister next to it but it did appear to have one end broken already. Anyway, I am posting the picture as it shows on the TV now in hopes that it might give a clue to a possible cause of the problem(s). Originally, I was experiencing horizontal lines only 6 inches up from the bottom, now I have horizontal lines over the entire display. Please see attached pictures of the TV (upside down). The first picture shows where the horizontal lines used to stop. Thank you again for the help.Leave a comment:
Thanks for the advice howardc64 and lotas. I am looking at ordering a 1/4 watt 100 Ohm resister from eBay. (They're cheap, under $3). As for the masking, I tried that and the best I could do is get a picture I already have which kind of gives me the impression that the problem is in the panel itself. I hope not so that is why I am willing to try relatively inexpensive fixes in hopes that it can be fixed. Again, Thank you for your help. RegardsLeave a comment:
yeah, microsoldering tools + technique. magnifying eye wear + tweezers etc..
Well, after 3 hours of trying to solder that microscopic resistor to replace the burnt one, I have found at least 8 ways that it won't work. The “pads” for the resistor have burnt up with the resistor so I have to try to solder a thin wire from the test point to the resistor or to the space where the “new” resistor will sit. What I found is when I have successfully soldered a wire to one side of the resistor the resistor is so small that when I try to solder the other side wire, the first one un-solders and falls off. That and being so small that the wires stick to the soldering iron, also, the resistor sticks to the soldering iron do to capillary effect of the molten solder. Trying to maneuver that tiny wire into position so that it won't short the very small distance to the other side of the resistor takes the hands of a neurosurgeon. I had finally soldered looped wire to both sides with the thought of cutting the wire when in place but when gently pulling the wire to ensure a good solder joint, the soldered end of the resistor came off. Like the Hee Haw song goes, “if it weren't for bad luck, I'd have no luck at all.” Anyway, I am going to step away from this for a few days so that my frustration can drain away and maybe figure out another way to do this that could work. Thanks for the help. Regards,
But I agree with lotus on post #34. CLK1-8 are gate driver lines. Theoretically disconnecting these on 1 side is no harm since other side of the screen has a duplicate set of circuit. Its interesting disconnecting 1 by removing the burnt resistor made picture worse. This might suggest there is a failure somewhere the burnt up that resistor. Could be the in the COF/panel.
Theoretically removing CLK1-8 from the burnt up side should allow the TV to work properly. But of course we don't know where the damage is and how it changed the circuit. Of course this is a bit scary because if pictures got worse, you currently don't have the tooling+skills to put back the resistors.
Another way to disconnect CLK1-8 (sent from t-con) on the failed buffer board is to find which pins on the t-con connector they are and block it out. The way to do this is to do continuity checks between CLK1-8 resistors and t-con connector to find the correct pins to block them out. This doesn't require irreversible desoldering but requires a bit of probing effort with fine OHM meter probe tips.
On design theory, one might ask "why have duplicated circuit on both side?" I think perhaps has to do with voltage drop if one side has to drive the voltage all the way across the screen to the other side via long distance. But this repair technique seems to work for LCD panels. Its the principle behind the "masking tape" fix.Leave a comment:
Thanks Howard, will give it a try. Lotas, you may be right but I would rather try soldering 1 resistor in place first before de-soldering 8. Thanks for your help.Leave a comment:
Some magnification aid and steady hands are necessary. Hot air on these tiny components probably need require some experience to not send it flying.Looks like 100 ohms are right. I didn't find any short circuits with the burnt resistor. I tried using a soldering iron to remove the resistor on the LG buffer board but it didn't work so I used my hot air station and achieved success. I decided to pull a second resister just in case and I took my eyes off of the resister for a second and it was gone so I de-soldered another one. I stumbled across the lost resister about 10 inches away. Didn't think the hot air gun would blow it that far away. I feel over my head because everything is so small. Those resistors are not much larger than the period at the end of this sentence. Regards,
If don't have hot tweezer, a wider knife tip soldering iron ti can heat both ends of the resistor simultaneously for removal. Board traces are also tiny and easy to lift so require care when soldering it on.Leave a comment:
Looks like 100 ohms are right. I didn't find any short circuits with the burnt resistor. I tried using a soldering iron to remove the resistor on the LG buffer board but it didn't work so I used my hot air station and achieved success. I decided to pull a second resister just in case and I took my eyes off of the resister for a second and it was gone so I de-soldered another one. I stumbled across the lost resister about 10 inches away. Didn't think the hot air gun would blow it that far away. I feel over my head because everything is so small. Those resistors are not much larger than the period at the end of this sentence. Regards,Leave a comment:
Try measuring burnt out resister circuit with nearby other resister circuits. You'd want to make damage didn't create any additional shorts. Use the identical circuit on other side of the panel for reference on correct measurements.Good morning Howard, hope you had a great weekend. I have a digital caliper and to the best of my ability the length measured 1.25 MM so with soldering I would guess that it is a 0402? I also tried to check resistance across the span of the burnt out resistor and got infinity reading. I will try to remove a resistor from the LG 70 buffer board and measure the resistance and let you know. Regards,Leave a comment:
Thanks for the offer on the resistors but I have a buffer board that I got from a LG 70 inch with a broken screen I got for free a while back and in circuit, they measure 100 ohms so that might be a standard but like you say, that is in circuit so I will have to check. Those resistors are sure small. Like a friend of mine from Mississippi would say, those resistors are smaller than gnat poop! Anyway, I will test the resistance of one removed from the board to confirm the value. I did test ALL of the burnt resistors and they did test around 100 ohms but that was in circuit. Regards, GilLeave a comment:
I have a few salvaged buffer boards. Can look and pull 100 ohm resistor and send it to you via USPS letter. Need to know dimensions of these SMD resistors. Maybe 0603? Just measure with a caliper.
https://eepower.com/resistor-guide/r...and-packages/#Leave a comment:
you might check lines on R100-R107 against adjacent lines on good side to see their behavior (probably no continuity?) and see if same on the burnt side. Just in case burnt damage has shorting the lines against each other somewhere.Yes, tiny and magnifying eye wear + microsoldering (or really thin tip) soldering iron necessary.
Thanks for confirmation the image below the flex was just shadow.
Start by checking the duplicate set of CLK1-8 on the buffer board on the other side of the TV for resistance (for reference). Driver signals goes up both side of the TV. Controls signals for which row to display. Only 1 side need to work for a perfect picture.
Yes, theoretically if R100-R107 are for gate driver lines, it can be unsoldered on one side of the panel and will still work perfect. But thats theoretical and we unfortunately don't have schematic OR know the complete damage (Just R104 or also other areas...)
Note the ohm readings taken are all in circuit. if resistor was 0 ohm, then in circuit test maybe can conclude its 0 ohm. Since you read 100ohms, don't really know if its the resistor or another circuit path. Surest way is to remove a good one (or unsolder one side only) to test. But this is quite challenging of course without all the microsoldering tools. I suppose can try 100ohm first and measure after soldering.Leave a comment:
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by Raulnngood morning! I have a problem with this Sony. The image has a pattern of black horizontal lines, I attach a photo of the lines. The power supply is external and emits a sound. I don't think it's because of that. Let's see if someone can help me.3 Photos
by kdanielAs stated by the person I collected the TV from, it just stopped working overnight. However, I still gave it a go to try and repair it.
There is a thread on the same TV but with slightly different issues where they had to tape connection points on the ribbon cable, so I want to see if this is repairable by any chance.
After bringing it home and plugging it in, the TV turned on with its backlight working but had no picture. After removing the back cover, the first thing I tried is to unplug one of the ribbon cables and the situation is as follows.
Left... -
by dvu0627I have a Sony Smart TV XBR65X900H that started to have horizontal lines on the right side of the screen (see attached picture). When I played video on Youtube green horizontal line at regular intervals(1/4") across the screen.
I replaced the T-Con board but the lines are still there.
I believe this issue is from the Main Board. Before I replace the Main board, I wanted to seek advise if this is the problem from the Main board or something else?
Thank you for the help.... -
First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
tried blocking LC lines too, but same results
is it lcd panel issue or tcon board issue?... - Loading...
