SAMSUNG UE32F4000AW dead no power
  • krsta
    • Nov 2020
    • 33
    • Croatia
    Hello.
    My mother in law turned the TV on it said no signal, she then unpluged the tv plugged it in and big bang happened. After that no led indicator was glowing.
    Took the tv apart and fuse was dead, rectifier is ok, but found the blown blue capacitor near the 9NM60N mosfet between drain and source. Can anyone tell me the value of this cap.
    And the mosfet driver model is unreadable like its spilled with some foggy glue.
    This is my first time trying to repair a TV, any help would be apreciated.
  • thommyX
    • Apr 2016
    • 96
    Re: SAMSUNG UE32F4000AW dead no power
    221k 1kV
    220pF 1000V
    Thomas
    • krsta
      • Nov 2020
      • 33
      • Croatia
      Originally posted by thommyX
      221k 1kV
      220pF 1000V
      Thomas
      Thank you for the info.
      I have ordered some from ebay. i hope it wont blow up
      • lotas
        • Jan 2016
        • 4843
        • Russia
        When this capacitor explodes, it can take this transistor with it, and the transistor takes a bunch of other components with it, you need to check everything carefully!
        • krsta
          • Nov 2020
          • 33
          • Croatia
          All diodes and resistors are ok, no shorted caps arround s3310 mosfet driver
          (cant find the datasheet).
          Mosfet :
          D -> S 0,54V (red probe on source)
          D -> S OL (red probe on drain)
          G -> D OL (black probe on gate)
          G -> S 0,65V (black on gate) resistance 9Kohm
          G -> S 1.2V (red probe on gate) resistance 9Kohm
          Looks like mosfet is dead. Ill replace mosfet and the driver and try then.
          This aluminum heatsing is a pan in the a** to remove, have any tips?
          • lotas
            • Jan 2016
            • 4843
            • Russia
            S3310 = FAN6755W.
            Your mosfet is more likely alive, there is no short circuit.
            • krsta
              • Nov 2020
              • 33
              • Croatia
              S3310 = FAN6755W.
              I will replace capacitor and fuse and see what happens.
              • lotas
                • Jan 2016
                • 4843
                • Russia
                Are these resistors alive?
                • krsta
                  • Nov 2020
                  • 33
                  • Croatia
                  0,3 Ohms each
                  • lotas
                    • Jan 2016
                    • 4843
                    • Russia
                    Ok
                    • RogerH58
                      • Jun 2023
                      • 5
                      • United Kingdom
                      Did you have any luck?
                      • krsta
                        • Nov 2020
                        • 33
                        • Croatia
                        Still waiting for the capacitors to arrive. They arrived in my country on 27.05. We have very slow post office. .
                        Once i ordered Gameboy from Japan.
                        It took 4 days to arrive in Croatia and 3 weeks for parcel to travel 2 km air distance from post office hub to my house.
                        • krsta
                          • Nov 2020
                          • 33
                          • Croatia
                          I had to order a new set of capacitors because the post office lost the package.
                          They arrived yesterday, soldered a new fuse and cap -> it works
                          Thank you all for help.
                            • 12328
                            • U.S.
                            So you only had to replace one capacitor and the fuse?
                            • krsta
                              • Nov 2020
                              • 33
                              • Croatia
                              Yes
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                              • kevin_allein
                                Samsung QE 75 Q 7 FGMTZG Power Supply dead
                                by kevin_allein
                                Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
                                In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
                                Does anyone have schematics for that board ?
                                Any good tip, what could be the issue ?
                                02-27-2025, 12:15 PM
                              • mrtek
                                Samsung UN43NU6950FXZA No power
                                by mrtek
                                Hi
                                Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                                Main fuse = OK
                                Back light LED = OK. Power them with aux power source
                                LED output = OK 156V
                                I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                                Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                                07-20-2025, 08:06 PM
