samsung ue55mu6192u dead signal LED
  • giova96
    • May 2023
    • 38
    • italia
    #41
    Re: samsung ue55mu6192u dead signal LED
    Originally posted by lotas
    Put a jumper on the motherboard between FB_TRDY_1 and FB_TRDY_3 and then you can determine which half of the panel is not working.
    In which area do I find these acronyms? I would like to avoid making changes to the card purchased (paid a lot) so that I can return it in the worst case
    • lotas
      • Jan 2016
      • 4564
      • Russia
      #42
      Post a high-quality photo, close-up, where the connectors for connecting lvds cables are located.
      I understand that you have the same behavior as on your own motherboard, on the new one you purchased.
      • giova96
        • May 2023
        • 38
        • italia
        #43
        I hope they go well
        • lotas
          • Jan 2016
          • 4564
          • Russia
          #44
          Originally posted by giova96
          I hope they go well
          • giova96
            • May 2023
            • 38
            • italia
            #45
            what happens once connected?
            risk of damaging the new card?
            • lotas
              • Jan 2016
              • 4564
              • Russia
              #46
              Nothing will happen to your motherboard, this is so that the motherboard understands that you have two lvds cables connected, with a jumper it will now display an image on either side, with one cable disconnected. And you can determine which half is not working for you.
              • giova96
                • May 2023
                • 38
                • italia
                #47
                so made the jumper, can i connect both lvds or just one?
                • lotas
                  • Jan 2016
                  • 4564
                  • Russia
                  #48
                  And all these manipulations must be done with the TV turned off from the outlet.
                  Why, put a jumper and disconnected one cable, checked, connected the first, disconnected the second and checked again.
                  • giova96
                    • May 2023
                    • 38
                    • italia
                    #49
                    okay
                    in this way I exclude that the right panel has problems?
                    if the panel is good, do I have to change the correct card?
                    • lotas
                      • Jan 2016
                      • 4564
                      • Russia
                      #50
                      Well, you check, then it will be clear, maybe the T-CON (25Q80) firmware is not working or the panel for it does not match.
                      • giova96
                        • May 2023
                        • 38
                        • italia
                        #51
                        https://www.youtube.com/watch?v=az2v...ovanniMarrocco
                        https://www.youtube.com/shorts/NzWfdCQDrnk
                        did as you said, this is the result
                        do i connect both lvds ?
                        • lotas
                          • Jan 2016
                          • 4564
                          • Russia
                          #52
                          Yes
                          • giova96
                            • May 2023
                            • 38
                            • italia
                            #53
                            Yes
                            it works, you see!
                            I let it test for an hour before putting the lid back on
                            Do you think I need to make some changes in the service menu?
                            • lotas
                              • Jan 2016
                              • 4564
                              • Russia
                              #54
                              If the panels (matrices) were the same, then nothing needs to be changed.
                              • giova96
                                • May 2023
                                • 38
                                • italia
                                #55
                                my CY-GK055HGLVBH
                                buyCY-GK055HGLVJH
                                change a letter
                                can i leave it like this?
                                • lotas
                                  • Jan 2016
                                  • 4564
                                  • Russia
                                  #56
                                  • giova96
                                    • May 2023
                                    • 38
                                    • italia
                                    #57
                                    Okay
                                    I fix the jumper and I will test it for a few hours
                                    thanks for your availability and the many information you gave me, I was about to throw away the TV!
                                    Thanks so much
                                    • lotas
                                      • Jan 2016
                                      • 4564
                                      • Russia
                                      #58
                                      Ok
                                      • Finderbinder
                                        • Jan 2012
                                        • 4
                                        #59
                                        I suspect I have a problem with IC1604 dump integrity too.
                                        Can anyone (lotas?) check and correct if needed my dump?
                                        All info are in photos attached.
                                        • lotas
                                          • Jan 2016
                                          • 4564
                                          • Russia
                                          #60
                                          Try.
                                            09-07-2024, 05:50 AM
                                          • glutton4punishment
                                            Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
                                            by glutton4punishment
                                            Samsung synchmaster 226BW.
                                            Before I replaced 5 caps, the screen was dim.
                                            Sometimes it wouldn't turn on.
                                            I opened it up, and found 4 bad caps in the pwr supply section.
                                            I unfortunately installee one backwards, i.e. wrong polarity.
                                            When I turned it on, I head a loud pop, and I quickly shut it off.
                                            The replaced caps are 3 860uF 25V's, and 1 330u 35V.
                                            One of the 860uF blew.
                                            I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
                                            03-18-2023, 12:49 PM
                                          • Ellos
                                            Samsung s21 sim recognized but no signal
                                            by Ellos
                                            I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
                                            I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
                                            From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
                                            I think I've located the SOC that...
                                            06-27-2025, 01:31 AM
                                          • Jacksoft
                                            Samsung 225MW EEPROM bootloop
                                            by Jacksoft
                                            I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                            Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                            So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                            According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                            Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                            02-14-2025, 04:18 PM
                                            09-06-2024, 11:40 PM
