samsung ue55mu6192u dead signal LED
  • giova96
    • May 2023
    • 38
    • italia
    Re: samsung ue55mu6192u dead signal LED
    Originally posted by Davi.p
    when reprogramming memories one must always make a backup of old fw, now if you have that you must provide it to Lotas
    Maybe I explained myself wrong
    the third place file is its original without having made any changes
    the wrong file of 50" I wrote it on the new ic not on the original
    today I deleted the original and rewrote the copy that lotas gave me
    • lotas
      • Jan 2016
      • 4907
      • Russia
      It's strange why you don't have 8 pin power. 3.3v, it should be permanent, maybe something was damaged when the flash was dismantled, take a high-quality photo of this area where this flash 25Q40 is located.
      • giova96
        • May 2023
        • 38
        • italia
        I can't do any better than that
        however all night without power, as soon as I connect it the LED lights up and responds to the commands from the push button panel but the TV does not start, in the meantime I feel that the CPU heatsink cools down, the whole thing lasts 30-40 seconds and then dies again and never turn on again
        at that moment all the voltages are present, then the usual defect that disappears at 3.3v and the 13v drops to 8.8v
        I think it's a cpu problem in the end
        • lotas
          • Jan 2016
          • 4907
          • Russia
          This usually happens when the software version of 25Q40 and eMMC does not match (do you have this exactly the original, native dump from this TV?), Try reading the dump from 25Q40 again and post it here, I'll see how it was recorded.
          And also check HDMI, if the signal lines are short.
          • giova96
            • May 2023
            • 38
            • italia
            the original dump is the one in the third post
            I have now rewritten the 25Q40 with the version you sent me
            Could it be an HDMI problem? why the tv died after a connection with the pc
            • lotas
              • Jan 2016
              • 4907
              • Russia
              #26
              HDMI is very sensitive to connection if it is connected to a PC hot, that is, when the TV is connected to a power outlet and at that moment you connect an HDMI cable to a computer that is also connected to a power outlet, a high voltage discharge occurs and the processor in the TV burns out and may burn the video card, you always need to connect the HDMI cable first, then just plug it into the outlet.
              And you need to disconnect the HDMI cable when the equipment is de-energized, that is, disconnected from the outlet.
              • giova96
                • May 2023
                • 38
                • italia
                #27
                so this could have happened and it's not an eeprom problem
                those times when the led lights up, the cpu heats up, i think the heatsink could reach about 35-40° in 30 seconds
                it doesn't seem normal to me
                • lotas
                  • Jan 2016
                  • 4907
                  • Russia
                  #28
                  There was also a problem with the firmware and I restored it, most likely the processor also suffered.
                  Check the signal lines on the HDMI socket with respect to GND, if they have a short or low resistance, then the processor is damaged, and this is only a motherboard replacement.
                  • giova96
                    • May 2023
                    • 38
                    • italia
                    #29
                    I'll look for another used board and keep you updated
                    many thanks for the support
                    • lotas
                      • Jan 2016
                      • 4907
                      • Russia
                      #30
                      Look for a board by number BN94-xxxxx, like yours, or look for one that is from "55" diagonal, it will be less of a problem to dock it with your panel.
                      • giova96
                        • May 2023
                        • 38
                        • italia
                        #31
                        I found a used board
                        tv UE55MU6125 board BN41-02568A
                        but mine is
                        tv ue55mu6192u board BN41-02568B
                        It could go well ?
                        • lotas
                          • Jan 2016
                          • 4907
                          • Russia
                          #32
                          Look for this number, I wrote, do not rush with other boards for now, you need to find the most compatible one.
                          • giova96
                            • May 2023
                            • 38
                            • italia
                            #33
                            This is my number
                            bn94-12646s
                            do i have to find this on the new one?
                            • lotas
                              • Jan 2016
                              • 4907
                              • Russia
                              #34
                              Yes, try to find it by this number, if you don't find it, you can look for another one, but it is desirable that it be from "55" inch.
                              • giova96
                                • May 2023
                                • 38
                                • italia
                                #35
                                I found a used one, but change the model of the panel, the last digits, could it be a problem?
                                my CY-GK055HGLVBH
                                buy CY-GK055HGLVJH
                                I also found some from the Netherlands but the TV model is not indicated, only the card
                                • lotas
                                  • Jan 2016
                                  • 4907
                                  • Russia
                                  #36
                                  Yes, you can take it, if anything, you can change it in the service menu to your panel.
                                  • giova96
                                    • May 2023
                                    • 38
                                    • italia
                                    #37
                                    update
                                    I bought a motherboard that was identical to mine
                                    instead they sent me this saying that it is compatible
                                    the TV does not start anyway, it has the red LED active and tends to turn on the backlight (I also hear a tick sometimes)
                                    card received UE55MU6120 BN94-12645A
                                    my board UE55MU6192 BN94-12646S
                                    should work for the seller...
                                    • lotas
                                      • Jan 2016
                                      • 4907
                                      • Russia
                                      #38
                                      Switch off the panel (disconnect the cables from the motherboard) and check how the inclusion behaves.
                                      • giova96
                                        • May 2023
                                        • 38
                                        • italia
                                        #39
                                        I try to disconnect the flats that go to the panel and it stays on, I connect the antenna and I also hear the audio
                                        I keep only one flat connected, the TV turns on and stays on but nothing appears on the screen, identical result in doing the test in reverse
                                        in practice, when I connect both flats, the TV goes into protection and restarts continuously (even if there is audio and video for a moment)
                                        • lotas
                                          • Jan 2016
                                          • 4907
                                          • Russia
                                          #40
                                          Put a jumper on the motherboard between FB_TRDY_1 and FB_TRDY_3 and then you can determine which half of the panel is not working.
                                            09-07-2024, 05:50 AM
                                          • glutton4punishment
                                            Samsung monitor Installed 1 cap wrong, now menu button dead, "no signal detected" msg
                                            by glutton4punishment
                                            Samsung synchmaster 226BW.
                                            Before I replaced 5 caps, the screen was dim.
                                            Sometimes it wouldn't turn on.
                                            I opened it up, and found 4 bad caps in the pwr supply section.
                                            I unfortunately installee one backwards, i.e. wrong polarity.
                                            When I turned it on, I head a loud pop, and I quickly shut it off.
                                            The replaced caps are 3 860uF 25V's, and 1 330u 35V.
                                            One of the 860uF blew.
                                            I didn't have another 860uF at home, so I tried it with a 1000uF 35V cap (I remember the reading of the 1k uF cap was close...
                                            03-18-2023, 12:49 PM
                                          • Ellos
                                            Samsung s21 sim recognized but no signal
                                            by Ellos
                                            I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
                                            I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
                                            From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
                                            I think I've located the SOC that...
                                            06-27-2025, 01:31 AM
                                          • Jacksoft
                                            Samsung 225MW EEPROM bootloop
                                            by Jacksoft
                                            I got an old Samsung 225MW TV with BN41-00825 motherboard.
                                            Since the TV has a buzzer when it starts it makes a beep. The main problem is that the TV goes in a sort of bootloop and beeps every 2-3 seconds.
                                            So I attached the VGA UART cable and read the debug data using a RT809H programmer:
                                            According to the Service Manual all the voltages looks good, so I made a backup of the internal flash and all the EEPROMs (1 Settings + 3 EDID) and cleaned the EEPROM.
                                            Now the TV boots but it's stuck on VGA. If I try to change the source it goes to TV, restarts...
                                            02-14-2025, 04:18 PM
                                            09-06-2024, 11:40 PM
