Samsung QN55Q80R Bad Panel Help
  • Diah
    • Feb 2013
    • 6355
    Re: Samsung QN55Q80R Bad Panel Help
    how many pins you masked now LOL.. could you count on which pin masked right now.. seem you have one of gamma under mask.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4289
      • Italy - Milan
      That whiteish picture sounds to me as you have bad vcom signal, maybe you covered that pin but it is mandatory to have it on to the panel, check vcom test point on the panel
      • Storyteller12
        • Jun 2020
        • 624
        Pins 19 or 20-26. It's hard to count those tiny pins.
        • Storyteller12
          • Jun 2020
          • 624
          Vcom is pins 6,7,8 and those are not covered.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4289
            • Italy - Milan
            havdd is there? try to change tape type with the thinner thing you have, usually kapton is quite thin
            • Diah
              • Feb 2013
              • 6355
              if this count correct and the pin chart of lotas correct then you have just masked half of the SPI... in this case i will remove the mask and just remove the spi carefully
              • howardc64
                • Jun 2017
                • 580
                Lots of transposed pictures and easily confusing. Judging from the pics in post #9 and #13, OP masked
                CN1301 (I'm assuming pic is CN1301 since thats the half thats not working) pin 74-82 (can't tell from pic if mask was continuous across this range). Service manual ( closely related, likely correct CN1301 pin out. link p112 for main board pic, p129 for CN_1301 )
                This is LC_VGP1_GOA, STVP1_GOA, CKVB1-4_GOA, CKV2-4_GOA
                Maybe should just try to mask out the 8 gate driver pins on the bad side (CKVB1-4 and CKV1-4) per post #14 (but I think post had wrong pinout diagram : CN1300 rather than CN1301) Probably can skip CKV1_GOA for total of 7 pins since short isn't there from current test. If that works, then gradually tried fewer CKVB1-4 CKV2-4..
                BTW, for precise experimental masking. I do it this way. Mark off 12 pin steps (service manual pin listing is in rows of 4) on the connector. Cut thin white paper precisely. Paper don't move when inserting the flex into the connector.
                • Storyteller12
                  • Jun 2020
                  • 624
                  Sorry was sick for a few days and didn’t have a chance to troubleshoot.
                  So, I removed SPI (25q80dvsig) chip and removed all the tape masking pins On lvds cable. Tv turn on and stays on but no image. Its not rebooting like it was. But if i unplug the side with the bad lvds cable i no longer get an image on half the screen like I did before. So I’m assuming in need the spi chip for it to produce an image.
                  Would a new spi chip fix the issue?
                  • lotas
                    • Jan 2016
                    • 4540
                    • Russia
                    #29
                    Why remove 25q80dvsig, it belongs to T-CON and it contains all your panel settings! Without it, T-CON will not work.
                    • Storyteller12
                      • Jun 2020
                      • 624
                      I tried doing the other winbond chip (25q40) as suggested by diah but the standby light didn’t come on and couldn’t power the tv on.
                      I just figured I would try this chip and see what happens.
                      Not really sure what to try honestly. I think this one is headed for the dump.
                      Any other suggestions?
                      • lotas
                        • Jan 2016
                        • 4540
                        • Russia
                        #31
                        It was rather about this SPI 25Q32.
                        • Storyteller12
                          • Jun 2020
                          • 624
                          Lol. My bad, I didn’t know.
                          Thanks for pointing out the obvious.
                          • Storyteller12
                            • Jun 2020
                            • 624
                            Ok, replaced the eeprom and removed the spi on buffer board and tv reboots like it originally did. I tape off pins again with spi removed and same washed out image.
                            • lotas
                              • Jan 2016
                              • 4540
                              • Russia
                              #34
                              Also check the TVS Diodes on the strips with a multimeter for low resistance or short circuit.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4289
                                • Italy - Milan
                                #35
                                have you tested vcom on the panel boards? It must be around 7,5v. Or maybe is something about bad vgh/vgl, low value.. test those plus avdd
                                • Storyteller12
                                  • Jun 2020
                                  • 624
                                  Sorry, I'm not a tech so you have to point me in the right direction where vcom, vgh,vhl are to measure them. I don't see anything labeled with them, but my eyes are the greatest either and the print is small.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4289
                                    • Italy - Milan
                                    #37
                                    the test points are probably on the panel's boards, search them with mgnifier or post sectional photos
                                      09-07-2024, 05:50 AM
                                    • maneatingmonkey
                                      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                      by maneatingmonkey
                                      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                      03-27-2024, 07:17 AM
                                    • stylishconsultant
                                      un60j620dafxza - Samsung No Display Problem
                                      by stylishconsultant
                                      Hi All,
                                      Need help.
                                      I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                      So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                      problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                      might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                      09-04-2024, 03:26 AM
                                    • NWArkGuy
                                      Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                      by NWArkGuy
                                      Well, I will be the first to admit that I screwed up...
                                      In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                      I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                      I have 2 that I have found and have in my possession. ...
                                      10-12-2023, 10:13 PM
                                    • Dodgethis
                                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                      by Dodgethis
                                      Hello all,
                                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                      09-11-2024, 07:39 AM
