LG 55LW5300 Backlights on, "Black Screen"
  • SmartSped
    • Oct 2014
    • 51
    • US
    Hello all, I was given an LG 55LW5300. When plugged in I get backlights but no picture. I checked voltages and found the Power On voltage to be 3.4V instead of 24v. All other voltages are normal at a powered on state. I did look around for solutions and found it could possibly be the IC's needing reflowed. I did this with my hot air rework station and this did not solve the issue. I'm not above replacing a board but I'd like to know which board it might be. Seems like a motherboard problem to me but I'm not 100% sure. Any ideas what the problem could be? Photos attached of boards and TV at On state. Note: I temporarily removed the heat sink on the main IC when I reflowed the solder.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 55LW5300 Backlights on, "Black Screen"
    Could be nand and spi, see if panel gets sca. Could also be a panel level short or tcon.
    • SmartSped
      • Oct 2014
      • 51
      • US
      What's an SCA and how do I check it?
      Also I'd like to correct something from my opening post. I didn't see there were a second row of pins on the main connector between the power board and main board. The power on pin reads 3.4v and the pin under it reads 24v. I checked all voltages on the second layer and they were all fine. No voltage on the error pin.
      • lotas
        • Jan 2016
        • 4845
        • Russia
        service manual
        • SmartSped
          • Oct 2014
          • 51
          • US
          Originally posted by lotas
          service manual
          Thanks, I checked the power on flow chart and seemed to be getting voltage everywhere it wants me to check. Everything seemed normal.
          I also tried to navigate to the cable channel to see if I have sound but I can't hear anything.
          Also, is it normal for the main IC to get too hot to touch after about 30 seconds of powering on (touching the heat sink)?
          Lastly, the TV started shutting off on its own after about 25 seconds of operating and turning back on. It wasn't doing this before.
          EDIT: Just looked at the T-Con board and the shielding and ribbon cables look a little toasty to me. Photos attached.
          • HTR-Informatique
            by HTR-Informatique
            02-09-2025, 06:51 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Francesco Valsecchi
            r9 290 "black screen"
            by Francesco Valsecchi
            hello i bought a faulty radeon r9 290 (black screen) to learn to fix gpu's, when it arrived i mesured resistances on 3.3 v and 12v both on the pcie connector and cables i have no idea on how to recognize 1.8v pex and 5v but i checked all inductors and none had a dead short only one was 55 or 140 ohms i don't really remember and i assumed it was memory i installed it on the pc and it delivered no image, not even a backlight so i installed it as a secondary graphics card using the igpu as primary, both device manager and gpu-z only showed the igpu so i assumed it was acutally a no detect even tough...
            08-18-2025, 06:44 AM
          • Swedishpower
            Dell G3 15 3500 black screen
            by Swedishpower
            Hello
            I have search everywhere for a solution for my problem, but cant find it anywhere.
            When I was away to trow some garbage i always look in the electronic bin.
            and this time i find a laptop.
            Dell G3 15 3500, when I get home i look at the battery, add one harddrive, plug in the powercord.
            the lamp for charmig is white.
            Tryed to start it, the screen blink for a second, the keyboard lightsup, the fans and HD starts.
            but no Dell logo.
            I tryed with a hdmi cable to another screen, still black.
            I started to search solution and tryed...
            07-06-2025, 06:18 AM
