Samsung 4K T-Con to Panel Connections
  • howardc64
    • Jun 2017
    • 626
    Been gradually learning about Samsung 4K T-Con signals during the problematic TU panel fault finding. Made a document and thought I post it here for reference and/or correction/addition by the experts.
    If anyone want to make edits and post new versions, please feel free
    Source is in Apple Keynote. Feel free to edit, increase revision # and post updates.
    https://drive.google.com/file/d/1rRl...usp=share_link
  • nomoresonys
    • 12205
    • U.S.
    Re: Samsung 4K T-Con to Panel Connections
    Thanks Howardc64, this will definitely help.
    • Diah
      • Feb 2013
      • 6376
      well done, but it still no one at professional stage / private or repair shop will be satisfied with the end result of the fixing. just because Samsung Panel are rubbish. so i will write instruction in wide letters......
      STOP BUYING KOREAN RUBBISH "SAMSUNG U"
      • nomoresonys
        • 12205
        • U.S.
        Thanks Diah, THIS too will also definitely help a lot of people, I hope they heed the advice.
        • howardc64
          • Jun 2017
          • 626
          Learned a few more things on these newer Samsung Panels
          • buffer board label to T-Con label correlation
          • finding probe points for buffer board labels
          • VCST
          • etc...
          https://drive.google.com/drive/folde...usp=share_link
            09-07-2024, 05:50 AM
          • x_orange90_x
            TCL 50S535 bad tcon or panel issue?
            by x_orange90_x
            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
            03-29-2025, 11:02 PM
          • howardc64
            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
            by howardc64
            • Prior owner tried a replacement main board. No difference.
            • Samsung 2x red blinking standby LED = panel fault
            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
            07-19-2025, 10:54 PM
          • advant
            by advant
            02-03-2020, 12:25 AM
          • NWArkGuy
            Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
            by NWArkGuy
            Well, I will be the first to admit that I screwed up...
            In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
            I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
            I have 2 that I have found and have in my possession. ...
            10-12-2023, 10:13 PM
