Samsung UE50TU8000K no picture or lanes on it
  • Dobsuk
    • May 2020
    • 127
    • England
    Hi guys, i am dealing with one Samsung 50TU8000K which was without picture - just was resetting itself constantly. Saw some videos and read some post about simmilar issue and the advise was to try to tape cut off method and started to put tape on some of the pins on this ribbon cable:
    And then i had picture but with lanes. Tried different pins and combination but could not managed to make it work without any lanes so far. Will keep playing with it though.
    The weird thing is that i tried it again without any tape on the pins and now i have picture with just few lanes on the rhs of the screen, watching it in front of it.
    And i am wondering now what could happened so to have picture now and should i keep trying to cut some of the pins with tape by any chance to make the picture without any lanes?
    Any advise will be really appreciate.
    This is the set from back view:
  • Dobsuk
    • May 2020
    • 127
    • England
    Re: Samsung UE50TU8000K no picture or lanes on it
    I noticed today that one of the horizontal lines is flashing slowly...if that helps somehow.
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      The fault did not go away by itself is all I can say, the TU series is known for lasting 1 year then developing horizontal lines or have no image at all.
      Put the tape back and mask the pins until you don't get lines and/or flashing.
      This "recovery" is common, the longer the TV is off, the more time the panel will last until it gets into terminal state.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        use a mini drill with diamond 1mm tip, hole in the connection between bad row and bad gate driver, press the drill at pulses, stop when the line go away, tv must be on with still image
        • Dobsuk
          • May 2020
          • 127
          • England
          I agree the fault did not go away by itself but honestly the only thing i can do was to put tape on few of the pins and got some distored picture at some of the pins and finally i tried again without any tape and got the full picture but these vertical lines. I will try to play with the tape again.... just need to recharge a bit patience
          • howardc64
            • Jun 2017
            • 626
            Posted a slide summary on Samsung 4K panel connections. Can help you understand what all the flex connection pins are
            https://www.badcaps.net/forum/showthread.php?t=118541
            A couple of additional notes
            • Use small paper cutouts to block off pins can go faster
            • You are probably blocking off CKV* and CKVB*. I think there are 4 of each. And STVP1. This older panel repair doc seems to suggest STVP1 has to be masked off in conjunction with the right CKV* CKVB* signals.
            https://www.electronica-pt.com/esque...-repair-65862/
            • Biruslapio
              • Nov 2013
              • 552
              • Brasil
              The most accurate and controlled way to do this is removing the resistors in the affected side panel board directly and replacing them with soldered jumpers, then removing one by one until you get the best picture possible, that is more precise however it requires significantly more effort than just trial and error with the tape.
                • 12192
                • U.S.
                Is there any reference, video or other that we can look at for this technique? I'm always on board for an easier way.
                • Biruslapio
                  • Nov 2013
                  • 552
                  • Brasil
                  https://www.youtube.com/watch?v=5PPPeFjplIU
                  The OP of another thread about a TU samsung linked this video, it is in spanish but the information is clear on what is the method being used, watch from 11:00 forward, 16:30, and 23:50 for the final result.
                  • Dobsuk
                    • May 2020
                    • 127
                    • England
                    Thank you, Really helpful PDF docs and advises. Unfortunately i am a bit busy in my work now and maybe will go for papre cutouts method when i find time as this is really consuming work
                    • Dobsuk
                      • May 2020
                      • 127
                      • England
                      Unfortunatelly I am not profesional TV electician. Just doing this as a hobby and do not have the neccessary equiment for this method. Thank you anyway. I am sure it will be helpful for all of us here.
                      • Donny2derby
                        • Apr 2023
                        • 228
                        • Uk
                        Would it be an idea to play around with the tape method until you find the best configuration of pins to block then follow those pins back to their respective resistors and make the changes you suggest?
                        • Biruslapio
                          • Nov 2013
                          • 552
                          • Brasil
                          That seems redundant, and extra work for the same result.
                          The disavantage to using the tape is the inability to block individual pins, for example, assuming the TV would give the best image with clock lines 4 and 6 blocked, but tape would block 4, 5 and 6, this is when removing resistors would be the superior method.
                          • PNI E.
                            Samsung eu75nu8000 no picture after tape method
                            by PNI E.
                            Hi guys, I write here for help me. I have a Samsung eu75nu8000. The Tv start to turn off and on, and I understand it was a panel problem, because if I take out a ribbon the Tv stay on. I tried the tape method but I have no picture but the Tv now stay on. My question is I have to give up because it s the panel? I notice that the chip vpm2sm it s really really hot, I can’t stay with my finger on it. Do u think all the problem of my panel is due to this chip, or u think it s a death panel and I can’t do nothing?sorry for my English
                            11-10-2024, 03:46 PM
                            09-07-2024, 05:50 AM
                          • triplefour
                            LG 75UN8570AUD panel issue fixed with tape.
                            by triplefour
                            I've been seeing a lot of the new TVs (samsung and LG only i think) maybe 1-2 years old suffering from sudden panel death and have been over 50% successful bringing them at least most of the way back to functionality if not all the way, with the tape masking of the LVDS pins method.
                            add this one to the list. the issue was on the left side of the panel and i ended up blocking just 3 pins on the connector that joins the two panel boards that make up the left side of the panel (it has 4 boards total) i didnt get the picture back to 100% perfect. i spent hours fiddling with which pins to block...
                            07-17-2023, 10:22 PM
                          • Mgiffune
                            by Mgiffune
                            06-09-2024, 10:28 AM
                          • Dodgethis
                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                            by Dodgethis
                            Hello all,
                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                            09-11-2024, 07:39 AM
