LG 47LA620V Same LED Failing Back Light Issues
  • jdawg99
    • Sep 2022
    • 11
    • United Kingdom
    Hi All,
    I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the same bloody LED blown. Seems odd that this is the 3rd LED in the same place in the same strip to blow. I've had similar issues on another TV and found a mod to reduce the current going to the backlight and this sorted that but with this PSU board (Vestel EAX64905501) I'm not sure how to do it.
    Any advice guys?
  • Diah
    • Feb 2013
    • 6344
    Re: LG 47LA620V Same LED Failing Back Light Issues
    no need any mode... just BL level bring it down to 59% .... also you put wrong SMD LED.. it should 4.7V build in zener diode
    • jdawg99
      • Sep 2022
      • 11
      • United Kingdom
      Originally posted by diah
      it should 4.7v build in zener diode
      4.7?
      • Donny2derby
        • Apr 2023
        • 228
        • Uk
        I’ve bid on the same make and model with the same fault described as above.
        What would be the correct way to diagnose and repair? Replace the suspect diode with a 4.7v zener diode then drop the backlight down to 57%?
        Exciting times!
        • jdawg99
          • Sep 2022
          • 11
          • United Kingdom
          Anyone have a link to the correct SMD led that I should be using please.
          • Diah
            • Feb 2013
            • 6344
            read this old threat you will find link too
            • Davi.p
              • Sep 2009
              • 4273
              • Italy - Milan
              i have fixed the same model by replacing some leds, if i remember was 3,7v, i don't know the watts, must match also that.. sorry no notes in the file, maybe when im on pc i find it in the emails
              • jdawg99
                • Sep 2022
                • 11
                • United Kingdom
                Thanks all, I will get some on order, hopefully it was just because I used the wrong spec LED.
                • jdawg99
                  • Sep 2022
                  • 11
                  • United Kingdom
                  Just an update, it was the wrong spec led. Ordered some marked for LG tv's and it worked fine.
                  • sigmeyer
                    • Feb 2020
                    • 147
                    • Serbia
                    As someone who does these jobs daily , if you are going to an extent of opening the tv with removing the screen , you should replace the whole set of strips . Soldering by hand is not a good technique, and you will have problems. This is tested and tried by me .. Always replace whole strips as a unit , if you want to have some serious success with this... otherways i wouldnt really bother
                      Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                      by sam_sam_sam
                      This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                      I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                      I am comparing them to a brand new one that I installed
                      The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                      I going to let it run for several days before I remount back on the wall next to the...
                      09-05-2024, 06:48 PM
                    • PNI E.
                      tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                      by PNI E.
                      hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                      02-20-2025, 08:36 AM
                    • tvguy12012012120
                      by tvguy12012012120
                      02-07-2025, 05:13 PM
                    • matthewmcconaughey
                      I need help with my friend Sony GDM-FW900 24” CRT
                      by matthewmcconaughey
                      Hello, Badcaps is my last resort. I am the first owner of the monitor. I reached almost every repair store in my area, but no one even wanted to hear about troubleshooting an old CRT monitor. At this point, I have been trying to figure it out by myself, but I have no idea where to start or look for.
                      I wish to know how to think and locate a failing component. I will put all my efforts to learn and contribute.
                      1. It started with a bright and greenish picture upon starting a cold monitor.
                      2. About 2 years ago, only on the cold boot, the screen started to occasionally flash with
                      05-16-2023, 03:15 PM
                    • boyebaran
                      hisense 65k560 back light problem
                      by boyebaran
                      hi to all
                      tv turn on and show logo(backlight on)than backlight turn off than red led in front blinking 7 time. the tv remote control working fine (sound on no picture).backlight changed same problem
                      in 65k560 how to remove protection of backlight? picture of inverter and sockets attached .
                      please advise me tnx
                      05-20-2025, 07:11 AM
