Hello, my name is carlos, I am new in this forum. I am sorry if I am not doing the right way to post over here. Please let me know if is wrong in that way I try no to do it again or let me know the correct way to do it. I have a dell plasma tv with no sound and no picture. I replace all the boards, but main logic board and the tv still no sound and not picture. When I replace the power supply board the tv work for about 2 weeks, but after I had lines on the bottom of the tv, so I ordered the y-sustain board, nothing the lower and upper boards, etc. still nothing. If you need more info, please let me know. Thanks in advance
Dell 42" Plasma tv
Tags: None
Re: Dell 42" Plasma tv
It is well known to have issues
http://reviews.cnet.com/flat-panel-t...tMain;userRate -
Sounds like you need to start with the basics.
Disconnect Z and Y boards check for VS voltage coming from power supply first. Also check for stand by 5v to the main board from the power supplyDid I leave the soldering iron on?Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
by Garret Matt.Hello,
I'm Working on replacing an Inductor on this Dell's board and I need to come up with a compatible replacement. As much as I would like to smash a comparable 2R2 in the same spot I'd like to confirm the specs before confirming a killed board. For my purposes I'd be happy with a second opinion on the replacement inductor or the actual schematics/board view. As this is a commonly used Dell Rugged in my local service area, schematics would greatly help in the future.
Thank you in advance for any assistance you can render.
Inductor In question. Buzzes like...-
06-20-2025, 01:21 PM -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
