Sony XBR-55X900F No picture, no sound no backlight
  • Nicktronic
    • Mar 2023
    • 247
    Re: Sony XBR-55X900F No picture, no sound no backlight
    Originally posted by howardc64
    Need schematic or some reverse engineering. Luckily I have the exact board in hand haha...
    • Traced REG12V to 5x DCDC for reduced voltages. Check voltage at all 5 points labeled 12V-A->E. Probably all 0V.
    • Check the 3 components between where REG12V comes into main and the GND plane right below it. See if any are shorted.
    BTW SONY boards are nice... lots of holes on voltage rails and have exposed copper for easy test
    Yes they are very nice! Very easy to do the checks you wanted.
    12V A through E have ~12.65 VDC
    3 components on REG12V input are good. (no shorts)
    • Nicktronic
      • Mar 2023
      • 247
      Originally posted by lotas
      Is there voltage at all on this connector, are these input fuses intact?
      Yes, voltages are present and fuses are good.
      • howardc64
        • Jun 2017
        • 654
        wow, thats 5 different DCDC paths all with 12v input. Are you sure all the coils/inductors next to them shows 0V DC on both sides? Sometimes its hard to actually get the probe on the contacts buried on the bottom.
        On REG12V, what is AC reading? AC just shows how much noise is above DC. We want to see near 0 for clean stable 12V DC.
        • Nicktronic
          • Mar 2023
          • 247
          Voltages are present....1.1VDC, 1.5VDC, 1.0VDC, 3.3VDC, 5.1VDC. I measured across instead of to GND.
          • Nicktronic
            • Mar 2023
            • 247
            No ripple on the DC. Nothing my DMM could read anyway..
            • howardc64
              • Jun 2017
              • 654
              Ok CPU has power. Heat sink on the right is the SOC/CPU and should be warm.
              Check SPDIF (optical connector next to ethernet) and see if red light inside the door. This provides hint on how far CPU got in booting itself up.
              How about TV's power standby LED? Does it flash ever? (plug in AC, press power button etc..)
              What voltage does the coil/inductor read at IC501? Board still have a 1.8V somewhere for eMMC IO voltage. IC501 is just above SOC so might be it.
              Heat sink on the left is LCD processor and since this tv has zoned backlight, probably also calculate individual backlight brightness level and forward to other boards to drive the zoned backlight brightness. Any warmth on this heatsink? Probably not if you have no t-con on and t-con voltage.
              eMMC PN on the board should be H26M52208FPR. Same Hynix flash memory generation as my HiSense thread ( link ) that show it likely died. This one is 16GB (mine was 8GB) Lets hope yours is not eMMC death. Know any usage history? I recently fixed a couple of LGs that was on average of 8 hours a day for 3-4 years and wore out the backlight LED's yellow phosphor filter and turn it blue.
              • howardc64
                • Jun 2017
                • 654
                This video is not your TV but 28pin connector PSU connector appears to be same. He jumped 3.3V STANDBY to POWER_ON and TCON_ON to confirm PSU can generate TCON_VCC12V. Probably don't need to do this yet but just stay informed
                https://www.youtube.com/watch?v=Y00I...ck%27sTVRepair
                He fixes a ton of these SONYs where the main board failure is always eMMC (he has lots of videos on this). No same main boards as yours (but likely same main SOC and similar eMMC generation from Samsung and Hynix. Has other videos of SONY dying ( link ) with same gen Hynix eMMC as your. All of these are also Android TVs which is also mine HiSense with dead eMMC.
                Anyway, Just FYI as diagnostic continues. I might have seen this movie before : Android TV, all voltages on main except t-con, no backlight, no standby light etc. Just dead because CPU can't boot with failed eMMC. Not much info on cheap HiSense but more repairs done on higher end SONYs.
                • Nicktronic
                  • Mar 2023
                  • 247
                  Thanks howardc64, I will check this all out. But based on what you said, and links provided it probably is the eMMC eh? Does that basically mean board replacement?
                  • Nicktronic
                    • Mar 2023
                    • 247
                    The eMMC is a 16GB Samsung KLMAG1JENB-B041 (S5YGGMJ0S)
                    • Diah
                      • Feb 2013
                      • 6562
                      it could be there SOS signal caused by open circuit at panel. disconnect at time on side of the panel or in case there are U ribbon on buffer boards you can also try disconnect one side then turn on see if the BL will turn on.
                      • howardc64
                        • Jun 2017
                        • 654
                        Require more diagnostic effort to be more certain. TV's user manual ( link ) shows a 3.5mm audio jack serial port (RS232c, pg11) for remote control. Maybe it will show boot up log msgs? But you will need USB to serial 3.5mm jack dongle. I built one here ( link )
                        Probably keep on doing other easy diagnostic efforts ( like @Diah's post #30 ) before taking the gamble replacing main board.
                        Yes, looks like all these SONY Android TVs are getting eMMC failure in both Samsung and Hynix brands.
                        • Nicktronic
                          • Mar 2023
                          • 247
                          https://www.badcaps.net/forum/showpo...2&postcount=28
                          Could you please provide the link to build the dongle. It didn't work in your last post.
                          • howardc64
                            • Jun 2017
                            • 654
                            sorry formatting error and link was on top. Fixed now. Anyway link is here again
                            fastest cheap dongle ( link ) from Amazon with Prime in US. ebay 2nd fastest. AliExpress cheapest + slowest.
                            Can buy multiple dongle specs. CH340G is good enough. Set TXD/RXD to 3.3V (use jumper thats pointing up. Here is final product
                            • Nicktronic
                              • Mar 2023
                              • 247
                              No red light at optical, no standby light at any point. I think you meant IC601? The coil there is about 1.5VDC
                              • Nicktronic
                                • Mar 2023
                                • 247
                                No change. Dead dead dead lol
                                • lotas
                                  • Jan 2016
                                  • 4859
                                  • Russia
                                  #36
                                  Here the problem is in the motherboard and rather in eMMC, and if the problem was in the panel, then the TV would turn on exactly and give an error "5".
                                  • Nicktronic
                                    • Mar 2023
                                    • 247
                                    Alright, so I guess need to find a replacement motherboard.
                                    • lotas
                                      • Jan 2016
                                      • 4859
                                      • Russia
                                      #38
                                      Look for a better native kit (Mainboard + T-con), there will be less problems to cross them (this is SONY).
                                      • Nicktronic
                                        • Mar 2023
                                        • 247
                                        Just to wrap up this thread, I received a new Main Board. As @lotas mentioned, it was not paired with the existing T-Con. I was able to follow this video to pair the boards and it's working great!
                                        https://youtu.be/3kYPjIHt8Lc (Mine worked after re-naming the file)
                                        Thanks for all the help!
                                          • 12330
                                          • U.S.
                                          #40
                                          Nice save, how much are those mainboards? wonder if they have them for the 900C.
