Philps QLED Q60B Model:QE65Q60BAU
  • lotas
    • Jan 2016
    • 4910
    • Russia
    #41
    Re: Philps QLED Q60B Model:QE65Q60BAU
    Instruction
    Attention !
    Everything you do - you do at your own peril and risk!
    1. Format USB flash drive (FAT32 only) and standard cluster size.
    2. Copy the downloaded file (upgrade_loader.pkg) to the root directory of the USB drive.
    3. Unplug the power cable from the outlet
    4. Insert a USB flash drive into a USB 2.0 port. If the firmware does not start, insert into the USB 3.0 port (USB 3 port is blue)
    5. Plug the power cord into a power outlet.
    6. You should get a message on the screen that says "Software update in progress" - this will remain on the screen until it completes.
    (I didn’t have this, it was just a black screen. Don’t be scared, the firmware is coming, you just need to wait 15-20 minutes)
    7. Once the software is installed and the TV has completely rebooted, do a complete "Reinstall TV via menu" > "Setup" > "All settings" > "General settings" > "Reinstall TV" > "OK"
    (I didn’t reboot on my own. There was a black screen and the Ambilight backlight turned green, I rebooted already from the remote control)
    • bohaboha
      • Nov 2012
      • 1047
      • sweden
      #42
      Originally posted by lotas
      Instruction
      Attention !
      (I didn't have this, it was just a black screen. Don't be scared, the firmware is coming, you just need to wait 15-20 minutes)
      (I didn't reboot on my own. There was a black screen and the Ambilight backlight turned green, I rebooted already from the remote control)
      Thanks again lotas this first line makes me a little scared "Everything you do - you do at your own peril and risk!"
      • lotas
        • Jan 2016
        • 4910
        • Russia
        #43
        This is a warning! This is not a simple firmware (update from the official site), it is a service firmware that restores the TV to its original state (as from a store) and if the light blinks during the update (power goes out), the usb flash contact with the TV or a bad eMMC flash (where is firmware of your TV), your TV may no longer turn on.
        • bohaboha
          • Nov 2012
          • 1047
          • sweden
          #44
          ok here an update of the situation with some pictures
          tv looks to work as it should with only half screen and sound what do you think?
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4546
            • Italy - Milan
            #45
            Please be clear, the tv boots after the system restore by usb? The actual state is the one already said.. the tv has probably side leds or top bottom edge leds, just to be sure you can build a basic led tester but almost surely leds are bad..
            • bohaboha
              • Nov 2012
              • 1047
              • sweden
              #46
              no haven't done anything yet
              • lotas
                • Jan 2016
                • 4910
                • Russia
                #47
                One of the two bars does not light up.
                https://aliexpress.com/item/4001094271260.html?
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4546
                  • Italy - Milan
                  #48
                  Self restoring software? Never heard.. i'm thinking about power supply problems or humidity problems..
                  • Diah
                    • Feb 2013
                    • 6614
                    are you blind???? my post No #2 before your fantasy come on...
                    before he had BL issue on right side.... now the total right side off. so no more shutdown... be happy you get this... with out software playing... repair BL only
                    he have separated left & right
                    • bohaboha
                      • Nov 2012
                      • 1047
                      • sweden
                      #50
                      so it's just two bars in this tv? maybe better to buy two bars in case something happens ahead
                      Once again, I want to thank you ,Davi.p,Diah,nomoresonys and Maalobs for the amazing help I have received : solution plus the links. No this thread is not over yet except I have to wait until I get the parts from Uncle Xaopin to show the result meanwhile I invite you to another thread that has not received as much support but is somewhat more kneey to solve :https://www.badcaps.net/forum/showth...light=bohaboha You are all very warmly welcome to contribute your skills because they are needed
                      • lotas
                        • Jan 2016
                        • 4910
                        • Russia
                        #51
                        Yes 2 led
                        • bohaboha
                          • Nov 2012
                          • 1047
                          • sweden
                          #52
                          Yes 2 led
                          thank you very much but that seller is selling by lot of 10 or is it possible for 2p
                          • lotas
                            • Jan 2016
                            • 4910
                            • Russia
                            #53
                            The main problem is waiting for you ahead, it is to remove the "65" panel itself without damaging it and not tearing the cables that go from the slats to the glass....
                            • lotas
                              • Jan 2016
                              • 4910
                              • Russia
                              #54
                              Look for their number "E-LED-CL-650-084-V2", you will find more, I posted a link to see what they are.
                              • bohaboha
                                • Nov 2012
                                • 1047
                                • sweden
                                #55
                                quite right I have to think of a way to take it apart in a sensible way that I don't know right now because as you say don't mess up the screen.how do you do it?
                                • lotas
                                  • Jan 2016
                                  • 4910
                                  • Russia
                                  #56
                                  It's all there (video), on disassembling large screens on YouTube.
                                  • Diah
                                    • Feb 2013
                                    • 6614
                                    repairing edge Led are piece of chess, i had never replaced strips. always do the whole led to be changed... remove them all with hot air gun... scratch the place of them with shave plate... place solder where it should be put one by one and apply head to the corner of solder
                                    as Philips i did replace before was 7320... i don't know what kind of LED in this set. 100 pieces best quality was just less than 7$
                                    • bohaboha
                                      • Nov 2012
                                      • 1047
                                      • sweden
                                      #58
                                      Hi everyone now the backlight kit has arrived and the TV is repaired and ready first I want to thank everyone who helped with this repair. it wasn't easy to fix even though I did everything myself. there were some strange things : Polarising film the thickest is cracked from the bottom edge and it has small firing points because it sat directly on the joints I have not been able to do anything because I have no replacement
                                      but i think if i lower the strength of the backlights it will help. and as soon as I find an equally big TV then I fix it- again thanks for your help
                                      This is the result
                                      • lotas
                                        • Jan 2016
                                        • 4910
                                        • Russia
                                        #59
                                        Everything is fine!
                                        • Diah
                                          • Feb 2013
                                          • 6614
                                          bring down the LED BL setting less than 50%.. so you will not facing this trouble again
                                            Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook Specification for Upgrade or Repair
                                            This specification for the Samsung 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U boardview and 13.3IN CHROMEBOOK 2 8GB/128GB FHD QLED MERCURY GRAY I3-10110U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help...
                                            09-07-2024, 12:10 AM
                                          • cstout
                                            DeLonghi AC Remote only accepts 3V
                                            by cstout
                                            Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                                            The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                                            I can't find any schematics...
                                            06-03-2024, 03:53 PM
                                          • Mc_Millian
                                            Toshiba 50lf711u20 fire tv remote not pairing
                                            by Mc_Millian
                                            I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
                                            The Tv model number is: 50lf711u20 Rev B.
                                            I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
                                            I've tried 3 different remotes which should be fully compatible with this TV.
                                            Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
                                            The power button, along with the volume,back,select, and directional...
                                            04-07-2022, 12:15 PM
                                          • edugimeno
                                            HiSense 55A7500F won't obbey to remote after power on
                                            by edugimeno
                                            Hi! I have this TV set that does the following:
                                            1) I press the red power button on the remote
                                            2) The TV turns on normally
                                            3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
                                            4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
                                            Then after it's off, it would again accept the TURN ON from the remote and same again
                                            BUT:
                                            -The remote does show the correct IR beam while observed thru a phone camera
                                            -The TV works fine while using the MiRemote...
                                            03-14-2023, 11:22 AM
                                          • rustinjust
                                            Please help, where can I get a remote for my subwoofer?
                                            by rustinjust
                                            I’ve got a subwoofer that I’ve had for nearly 20 years, it did come with a basic remote which I’ve lost. It’s a generic make of subwoofer, I can’t see a brand sticker on it. It comes with 2 speakers.
                                            Question recently I’ve connected it up to my tv which has greatly improved the sound on my tv, however I’d like to be able to mute the subwoofer when ads come on or just mute it when the phone rings etc. I tried using a cheap all in one tv remote on the subwoofer and the volume button would only work to increase volume but not turn it down or mute it
                                            Is there...
                                            10-28-2023, 03:43 AM
