Bluething SDI->DVI converter
  • Xenon-Codex
    • 186
    • Finland
    Does anybody have experience with these? It does not detect any kind of input, status says alway Input None no matter what I put in.
    https://www.bhphotovideo.com/c/produ..._to_DVI_I.html
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
    MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
    The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
    Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
    10-23-2024, 03:23 AM
  • gizmo1990
    What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
    by gizmo1990
    I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
    The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
    10-21-2024, 08:02 AM
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • Kemer
    Led status indicator light transfer plastic
    by Kemer
    Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
    There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
    The plastic piece doesn't appear to be broken.
    1. What are your suggestions for resolving this issue?
    2. Is the plastic piece made of special ma...
    08-19-2025, 07:02 PM
