LG 32LN540B power on problem
  • stomanata
    • Apr 2016
    • 82
    The power board is EAX64905001 (2.7), over
    internet i found wiring for (2.4).
    May be the whole problem is that
    i have 3.13V instead 3.5V. When i power up tv
    the red led light up for ~10secs, then power off
    for 3-4sec, and again power on, power of, etc.
    In version 2.4 output 3.5V came from main transformer - D203-
    C201- LB201- C209-C210.
    But in my case (2.7) 3.5V came from IC202 (NR891D).
    In hid datasheet there is only info that from output must
    have 5kohm resistor to FB to produce 3.3V but i can`t find
    what control and how to calculate output voltage.
    I change both capacitor near to LB201, but this did not change
    output voltage of 3.5V line - it stay 3.13V.
    What other to check?
  • nomoresonys
    • 12206
    • U.S.
    Re: LG 32LN540B power on problem
    Pictures?: https://www.badcaps.net/forum/showthread.php?t=39740
    • stomanata
      • Apr 2016
      • 82
      Thanks. I upload pdf that i have for 2.4
      • nomoresonys
        • 12206
        • U.S.
        If you haven't already, unhook cable from powerboard to mainboard and test the pins on powerboard, see what voltages you get and if they are steady.
        • stomanata
          • Apr 2016
          • 82
          It is better - 3.45V
          So, may be fault mainboard?
          • nomoresonys
            • 12206
            • U.S.
            seems to be dragging it down a little, try testing the powerboard as stand alone, with tv unplugged from power, unhook cable from powerboard to mainboard on mainboard side, I jump it thru the end of connector by tracing the wires from the powerbord side to the cable end, take three 1k ohm resistors and jump from PWR-ON TO 3.5, DRV-ON TO 3.5 and P-DIM to 3.5, plug power cord in, see if backlights come on and stay on and the other voltages come up to expected levels.
            • stomanata
              • Apr 2016
              • 82
              There is backligh, voltage is 66V and other voltages seems to be OK
              • nomoresonys
                • 12206
                • U.S.
                Seems like a mainboard issue then.
                • stomanata
                  • Apr 2016
                  • 82
                  May be yes. Thanks for all your support
                  • theone111
                    by theone111
                    3. Problem: TV shuts down
                    07-22-2024, 10:36 AM
                  • Duranitron
                    Asus x512dk rev 2.1 power on problem
                    by Duranitron
                    When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                    Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                    11-26-2024, 10:22 PM
                  • EazyBone
                    LG OLED55C9PUA power problem
                    by EazyBone
                    Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                    Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                    I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                    The power supply to t con is different story.
                    This...
                    06-23-2023, 07:43 AM
                  • Dr.d
                    Help please..Lenovo ideapad 5 14itl05 power and charging problem
                    by Dr.d
                    I have a lenovo ideapad 5 14itl05, board LA-K321P, That will only power up on Battery only, or with battery disconnected and power adapter only. If battery is connected and usb-c power plug connected. It only works on battery and will not charge. I can however force it to charge by connecting the battery from a disconnected state while the power USB c plug is powering the laptop.
                    Additionally....to add to this strange situation. The usb-c power plug ONLY works to power the laptop on one side when inserted into the boards power usb c plug. If you rotate it 180 degrees, the board gets...
                    04-05-2024, 11:48 AM
                    03-31-2024, 02:12 PM
