Panasonic TC-P50U50 Powers Off - 8 blinks
    • 12116
    • U.S.
    Re: Panasonic TC-P50U50 Powers Off - 8 blinks
    Seems to be a tough little problem, maybe send it to one of those trusted fixers on ebay.
      • 12116
      • U.S.
      One there but they may be thinking it's the same usual 4 part repair, if I were going to let them try to fix it, I would contact them and tell them I already tried replacing those 4 parts and see what they have to say: https://www.ebay.com/sch/i.html?_fro...acat=0&_sop=15
      • nobbnobb1
        • Nov 2019
        • 76
        Check for continuity
        between pins 1 and 2 of connectors
        SS52 ~SS57on the SS board. Do not
        plug in the TV.
        Yup, already did that as part of Panasonic's troubleshooting guide. Does not appear to be any issues as I got the following values (roughly):
        SS57 - 1.3 ohm
        SS54 - 1.7 ohm
        SS55 - 1.4 ohm
        SS57 - 1.8 ohm
        • nobbnobb1
          • Nov 2019
          • 76
          If continuity is ok in all the connectors, problem is prolly in the ss board, if thats ok could be panel problem. Where did you get the replacement parts?
          Aliexpress. Only note is that the only part I did NOT replace were the 2x 5.6 ohm resistors because I tested them and they were fine. Did not want to replace these because of how difficult it would be to solder them.
          I guess my last resort if we can't try anything else would be to replace these, but I can't imagine them to be a problem if they test properly.
          • nobbnobb1
            • Nov 2019
            • 76
            Thanks for that suggestion. For $70, it's probably not worth it on this Tv at that point and I'd probably give away the TV to let someone else try. Was hoping to be able to get this unit working from a hobbyist perspective. Hate seeing stuff go to waste!
              • 12116
              • U.S.
              #26
              I hear you, I don't think I would either, the test in post #16 with tv staying on narrows the problem to SS board or panel, I am not sure how to determine which one, maybe another member knows if it's possible.
              • nicholas1110
                • Aug 2012
                • 127
                • usa
                #27
                It is very important to replace those 5.6ohm resistors. If the transistor was shorted the resistors were damaged even if they read close to the correct resistance. I have seen many of them black and burnt and still read correct resistance.
                • nobbnobb1
                  • Nov 2019
                  • 76
                  Dang ok, I'll go replace them later and report back. They're surrounded by other stuff and looks like a pain in the butt to get off!
                  • Biruslapio
                    • Nov 2013
                    • 552
                    • Brasil
                    #29
                    Resistors either resist or resist a lot(open circuit after failure).
                    The thing to do is desolder ALL the big transistors and diodes related to power and switching for the plasma panel, measure them off circuit and check for a partially bad one, that is leaking current in reverse polarization or even has too low forward resistance.
                    • nobbnobb1
                      • Nov 2019
                      • 76
                      That's a good point. However in my case I'd probably like to avoid doing so. I can feel the traces buggering up on the transistors/diodes that I replaced. So I'd like to really avoid any more stresses to the circuit board if I don't have to!
                      • Biruslapio
                        • Nov 2013
                        • 552
                        • Brasil
                        #31
                        The replacement you did was not necessary since that is for when the DG302 blows up and burn the resistor + their gate driver and the RF diode next to it.
                        There may be fake DG302 in the market as for every common IGBT used in plasmas (most famous fake parts are toshiba, fairchild and renesas).
                        I circled on the SS board image points of interest, all the important diodes and transistors, plus TPVe testpoint (voltage generated by SS board), it must match the service manual specified voltage, and those capacitors + the big inductor can develop bad soldering joints as aging occours.
                        • nobbnobb1
                          • Nov 2019
                          • 76
                          I have replacement 5.6 ohm SMD resistors (R041 and R051), but then I just noticed the ones I bought are physically too small! I could probably be creative in using a blob of solder to jumper it together. A little tough getting the right size because I got these off Aliexpress and seemingly none of the sellers list out the dimensions!
                          In the meantime, I powered on the TV with SS33 disconnected and TPVe tested 170V as per the service manual. Those other transistors I tested in-situ and they don't seem to have any abnormal shorts. I also attempted to do the typical gate/drain/source test using the diode function but it doesn't seem to work on ANY of them. I'm guessing it may be the way it's mounted to the board and/or being interfered with other components? Not sure if I'm doing something wrong but it's fishy that I was not able to test ANY of them properly. I've done the transistor test a dozen times before and I also made sure to look at the pinout from the appropriate datasheets.
                          • nobbnobb1
                            • Nov 2019
                            • 76
                            Just replaced the 5.6 ohm resistors. No luck, still the same problem. Pretty darn close to just giving up on this SS board now.
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • Biruslapio
                              Panasonic P58V11B 8 and 12 blinks error "fix"
                              by Biruslapio
                              Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                              Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                              04-13-2021, 07:13 AM
                            • jm1234
                              Panasonic plasma TX-P42ST50 - 6 blinks
                              by jm1234
                              anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                              It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                              I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                              I checked that board for any obvious faults...
                              05-22-2024, 06:59 AM
                            • Alicat
                              Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                              by Alicat
                              Stopped by this site trying to fix my parents Panasonic Plasma TV.
                              Model number is TH-50PZ85U
                              Power comes on and the red power light stays on solid.
                              Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                              I also hear a few clicks.
                              I also think my parents said there was a thunderstorm and the TV failed after that.
                              Section 6 in the service manual talks about power and no screen,...
                              10-30-2024, 10:09 AM
                            • CrewmanRedShirt
                              Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                              by CrewmanRedShirt
                              Hello all,
                              As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                              07-13-2024, 11:02 AM
