Philips 55pus6754/12 FZ3A Set Option value dilemma
  • alltvrepairs
    • Jan 2014
    • 211
    • Malta
    I need to change the main board for this set. I have a new identical board but for a smaller model 43PUS6704/12 FZ3A
    The picture is not good and remote seems not to work either.
    The Set Option on the rear of the TV says 042 as shown in pic.
    The Service manual lists this model but with another screen with a mentioned Option Code of 109. I assume that I need to use the one on the back of the TV.
    The problem I don't know how to tackle yet is the remote issue as not responding. Remote works on another Philips TV.
    The Manual mentions U409 Eeprom. Need to locate it and try to swap just in case.
    Anyone has experience on these TVs?
  • William1967
    • Nov 2017
    • 203
    • Netherlands
    Re: Philips 55pus6754/12 FZ3A Set Option value dilemma
    Check if the IR sensor is present on the small IR PCB, some IR sensors have bad soldering and some are gone.
    The setoption code is 042, enter 062598 HOME 042. If that does not work try panel ID 128, this can be entered via Factory mode. Home-1999-backspace.
    The list you have could be from a different FZ serie and is therefor not valid.
    If the setoption does not work it might be possible that the software must be updated to install newer NVM numbers so the tv can recognize the code.
    • William1967
      • Nov 2017
      • 203
      • Netherlands
      Option numbers:
      080 001 020 068 002 096 004 077
      235 002 022 004 001 008 128 000
      • alltvrepairs
        • Jan 2014
        • 211
        • Malta
        The option codes you shared were spot on!
        Tks for your help as well. Issue resolved.
        • eurgenca
          Philips TV 43pus7505 setting display option code, help please.
          by eurgenca
          Hello.
          I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
          So I ordered a used CPU board, and now I have wired picture.
          I think the problem lies in display option code. According to SM, the command for setting
          display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
          But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
          or can I manually edit option code in SAM.​
          10-07-2024, 02:09 AM
          Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
          This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-06-2024, 08:00 AM
        • marekk
          Philips 55PUS6754 with lines after few seconds
          by marekk
          I have tried to replace TCON but it didn't help.
          The strange is that it shows Philips logo before the lines. Tried to cover some of the lines with tape on the ribbons to the screen but had no success.
          screen: tpt550u2-eqya3.g
          tcon: 6870C-0769A
          I will appreciate any help
          Many thanks
          Marek...
          11-03-2022, 03:00 PM
        • Jimmy1979
          philips 55pus6754/12
          by Jimmy1979
          Hello
          Can someone help me out.
          I have a philips tv whose ambilight has a problem
          has. if I turn the TV off and on again, the ambilight no longer works until it has been disconnected from the power. i have tried settings and factory reset without success.
          Does anyone have any idea what this is and if it can be fixed.
          thanks...
          02-17-2022, 01:03 AM
        • aidanmo
          Philips 43PUS7506/12 - Loud blown out sound
          by aidanmo
          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
          I thought maybe the speakers got damaged, so I replaced them - no dice.
          • Using the internal speakers, it always happens.
          • Using the headphone jack, it never happens.
          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
          02-28-2025, 03:13 PM
